Tractor Talk Discussion Forum
Ford F150 mechanics!
onefarmer
04-30-2007 09:18:39
My '95 F150 will go into what I think is limp in mode. The check engine light comes on, it runs very rich, no power, and won't shift out of second. While in this mode I can't pull any codes. However when it cools off and goes back to normal I run the codes and it says there is nothing wrong. Is this the computer itself going bad? It has 200k+ and otherwise runs very good.
Bob
04-30-2007 17:28:23
 Re: Ford F150 mechanics! in reply to onefarmer, 04-30-2007 09:18:39
A "flaky" MAP sensor will cause all sorts of weird problems.
Bryan in Iowa
04-30-2007 10:34:40
I had one similar to this come in shop awhile back . Finally found shorted connector at computer harness. Injectors were grounding . Took some digging to find it . Might try tugging on harnes by ECU when it is acting up . If nothing, unplugged connector and check for moisture , arching , corrosion .
onefarmer
04-30-2007 17:01:52
 Re: Ford F150 mechanics! in reply to Bryan in Iowa , 04-30-2007 10:34:40
Sounds like a good idea. I just found the computer in the firewall under the hood hinge. I try it when it acts up next.
Bryan in Iowa
04-30-2007 18:36:27
 Re: Ford F150 mechanics! in reply to onefarmer, 04-30-2007 17:01:52
Yep , they get alot of water on them . this one acted up everytime it rained,might try misting it with spray bottle while moving harness .
