Tractor Talk Discussion Forum
crank warning
charger
04-29-2007 01:10:39
Will my te 20 give me any crank warning like the way a car engine will knock, or do you just tear em down anyway? When I got her I changed the front seal. Both leaked but the front was more than I could bear. I notice after its ran a whileit to is now back to sweating slightly. No where near like before, but just a slight sweat. Is this normal? Is the seal taking a while to runin? OR do I have bearing wear causing the seal to seal poorly?
RAB
04-29-2007 04:19:08
 Re: crank warning in reply to charger, 04-29-2007 01:10:39
By the time it is knocking it is too late. You might get away with things a little more with spun-in bearings, but with thin wall bearings it is already far too much clearance.
Not sure of the engine timing cover/seal arrangement on the engine, but there are tricks to get over a wear line. Using a sleeve for a new surface is one, using a different seal (to seal slightly further along the shaft) is another. Is there an oil thrower inside that seal? Was the timing cover properly aligned (if appropriate) when the new seal was fitted? Is there crankcase pressure building up for any reason? Is the oil level at the correct level (even does it have the correct dipstick?)? I am asuming it is leaking around the shaft and not around the seal. There is more to a simple oil seal than just simple. From your post I am presuming you don"t know too much about things like this. Also I am not sure what you mean in your post when you say "both seals". If it is the rear crankshaft seal you may eventually get oil on your clutch if it gets too bad. The design takes care of small amounts leaking but not lots - and I don"t know what you think is too much to bear - too subjective for me.
Hope this helps.
Regards, RAB
richard in nz
04-29-2007 02:26:17
Put a bar under the crank to check for exessive lift, it acceptable try, if possible, to make the new seal run on a different part of the crank by pushing the seal further into or out of the housing.
