Tractor Talk Discussion Forum
AC Industrial tractor identification
ken brownell
04-28-2007 21:14:49
I just bought an AC industrial tractor and cannot identify the correct model #. I have seen pictures of the I60 and it looks different. It looks for similar to a D12. It has the same 3 point hitch arrangement and narrowing of the drive tunnel behind the clutch. It does have power steering different than the D12, but that may be due to the fact that it is an industrial model. How can I determine for sure what the model number is? What is the best place to order repair parts?
Dave Anderson
04-29-2007 19:29:04
 Re: AC Industrial tractor identification in reply to ken brownell, 04-28-2007 21:14:49
I believe you have an I40, or I400. As you suspected, it is based on the d10 or d12. A couple of good books to read Norm Swinford's Allis Chalmers construction Equipment, and C. H. Wendel's The Allis Chalmers story. To find serial #, look at carb side of engine. Find the seam where the motor meets the tranny. Stamped into the motor side of the flange is the motor #. Stamped into the tranny side of the flange is the tractor serial#. Both of these flanges are about 1/2 inch wide, and at the point of stamping, the flange is at about a 45 degree angle to the ground. An easy way to tell if it is late model(I400), is that the muffler and hole in the sheetmetal is oval. Make sure that the hole has the factory oval, not chopped,hacksawed etc.
Dave Anderson
04-30-2007 18:39:54
 Re: AC Industrial tractor identification in reply to Dave Anderson, 04-29-2007 19:29:04
One other thing. D-10 is a 1 row tractor. D12 is a 2 row tractor. That is the only difference. I40 is based on the D-10/12 series I and II tractor. I400 is based on the D-10/12 Series III tractor. (it is more modern than the I40, and rarer) The reason I don't differentiate between D-10/12 is because the only different part is the rear axle width, and the axle spacers. Sometimes the wide or narrow spacer was used on the industrial tractors, depending on the specs.
Dave Anderson
04-30-2007 18:31:07
Motor parts will interchange with D10/12. Most other parts will, too. There are a few hydraulic goodies and brackets that are different, depends on how the tractor was originally spec'ed out. These tractors were loader/backhoe combos, forklifts, highway mowers, concrete hammers, numerous others. Suggest you try this question at the unofficial Allis Web page. I may have a manual or two laying around, and maybe some parts. Manuals (D-10/12) are still available from Agco dealers, generally for le$$ than online. Get the parts manual-it shows exploded parts diagrams, very helpful. Email me and let me know what you're looking for.
Ken Brownell
04-29-2007 19:40:00
Thanks for the info that helps me identify the tractor model. My next problem is now that I know I have an I-400, (I assume that means it was based on the D-12)I cannot find a repair or parts manual for the tractor. Is there any significant diference between the D12 and I400 other than how heavy it was built? did it use the same engine, tranmission and 3 point hitch? I will purchase the book suggested and hopefully that will help.
Ken
