Tractor Talk Discussion Forum
Crack block Case trouble
Jacob S
04-26-2007 04:55:33
I have1950"s case tractor, it is about 30 hp it has a crack in side the block. My dad wants to put some of that liquid block to dump down radiator to see if it will fill the crack. Were do I find this stuff. And will it work.
Martini
04-26-2007 05:14:33
 Re: Crack block Case trouble in reply to Jacob S, 04-26-2007 04:55:33
Check out 'Iron Tight', got mine at NAPA.
Repeat annually or as required. $20. fix,
but check your fluid levels often if go this way.
If the crack is visible from the outside, drain
fluids, clean out crack well, and apply JB Weld.
