Tractor Talk Discussion Forum
fire burned tractors
husky
04-24-2007 18:44:51
hi how many here have rebuilt/ restored a fire burned tractor ????? was it worth it ??? how difficult was it to do ???? looking at one to redo any suggestions are welome THANK YOU
dan hill
04-26-2007 14:34:48
 Re: fire burned tractors in reply to husky, 04-24-2007 18:44:51
Dont try it.I bought a burnt jd h.I used the trans mission gears, there was oil in the trans mission.Worked ok .The axles were bent and the front frame was bent from the heat.I gave the hitch to a friend but warned him to have it copied by a welder.
Kelly C
04-25-2007 18:52:44
I have talked to a few tractor repairmen about this topic. All had done one or more.
All said they would never do one for them selves.
They said that the heat from the fires do strange things to the metal parts. Getting brittle ect.
My self I wouldn't do it.
JDknut
04-25-2007 09:14:23
A dude I know had a Jubilee burn up. He had a Deere dealer restore it, and it ended up costing $6,000 to restore it, to new tractor standard.
msb
04-25-2007 07:44:11
 Ammonia burned tractors in reply to husky, 04-24-2007 18:44:51
Worst one I ever did was a 4020 that was rearended on an interstste (No he should not have been out there) Had a mounted anhydrous toolbar and two wheel tank. Hit by a semi.The ammonia tank was ruptured. The truck driver died. The hired tractor driver was thrown off in the sideditch, but was only slightly injured.Mostly ammonia burns as I recall.Probably happened 35-40 years ago. Anhydrous ammonia rusts everything it hits. I think the paint was even rusted.lol.
jdemaris
04-25-2007 06:00:41
I've done several - and they all wound up being much more difficult than they looked. I bought a Deere last year that was in a "light" fire with very little visible damage - pretty much just from the hood up. What a mess. All the bolts stuck, I ended up rebuilding the engine, etc.
Tx Jim
04-25-2007 03:11:24
I was a service manager for a JD dealer where a burnt JD 4020 was refurbished. I think we never got all the leaks fixed. I would never want to attempt another one. I'd let the bone yard have it. They are very messy to work on also. Tx Jim
730virgil
04-24-2007 20:39:16
when i was just a kid i worked for an ollie dealer. one of his customers had 1800? burn he and his son rebuilt it. when they got done said never again the tractor gave them lots of trouble afterwards while it had been good tractor before.
MSD
04-24-2007 20:28:20
I did a G JD for my son a couple of years ago. Had the tires burned off and no paint left. I overhauled it. Found that where the fire was the hottest it burnt the gaskets. I would have changed all of them anyway when doing the overhaul. It turned out good. This one probably wasn't the hottest one I have seen though.
Joe(TX)
04-24-2007 19:05:45
I rebuilt one that was burned. The sheet metal was not warped too badly. I had to replace all the tires, and most of the seals in the engine as well as rebuild the injector pump. Any thing that was not steel or iron did not survive.
It ended up costing as much as buing another tractor. It was also a lot of work to clean it up to paint.
RayP(MI)
04-24-2007 18:54:20
Depending on the amount of fire damage, I would be very leery of "em. Father-in-law had one in a dairy barn full of hay burn down, to the ground. Tractor was a total loss. Heat was so great that metal was probably beyond salvage.
