Tractor Talk Discussion Forum
Super C Fast hitch on a C
48C-MAN
04-24-2007 15:30:37
Will a fast hitch from a Super C fit on a C, and if so how well do the three point conversions work and how much will it lift safely? Thanks
Ray
04-24-2007 18:17:44
 Re: Super C Fast hitch on a C in reply to 48C-MAN, 04-24-2007 15:30:37
Yes,they will interchange but,you can buy an aftermarket 3pt that will fit and you won't have to mess with adapters.
the Unforgiven
04-24-2007 18:03:39
I don't know how well it interchanges, if it does you will need every little piece or it will be a hassle. I put one on a Super C but had the donor tractor right beside it, even changed the hydraulic unit to get the right arms on it. But I really like it, you can change the angle front to back as well as side to side, it is really handy. I copied a larger IH adaptor and it works real nice, kept it as short as possible. The heaviest implement I carry is probably an old Bush Hog brand 6 foot mower. It makes a real handy little tractor, I almost forgot where I left my 8n Fords.
georgeky
04-24-2007 17:56:46
Yes, if you have all the parts including the tool box/seat mount it will bolt right up. The conversions work fairly well, I don't use them, but I have lots of fast hitch implements and don't need them. They will lift more than you can move with them. They will lift front wheels right off the ground. The conversion kit will make this worse as it sticks back farther from the axle. I can move small rolls aof hay anywhere with mine and a fast hitch bale carrier. The rolls are around 800 pounds.
