Tractor Talk Discussion Forum
Cutie Pie !!
ShepFL
04-24-2007 10:12:56
third party image
I am learning tractors ain't just a guy thing. CASE LADY and this pic prove that.
Las weekend my BSA Troop 150 helped the F.O.E. with a soon to be annual BBQ cooking contest.
For general interest I brought along my trailer queeen tractor (1939 Allis B) and this little girl just fell in love with it.
Her Momma tried to keep her away but she insisted. She wanted to drive it! She wanted to stay there and play on it.
As a compromise for her and Momma I let her climb around and then took pics. I sent Momma the pics today via email.
This little girl came back 3x during the day to play on the tractor. She absolutely loved it!!
Silly Boys, tractor are for girls too I guess :)
MLD
04-25-2007 06:39:33
 Re: Cutie Pie !! in reply to ShepFL, 04-24-2007 10:12:56
It just something in the blood, that some of us are born with, male or female. I'm a big green & yellow fan but pretty much like all tractors. It would be neat to own one of every brand to compare too.
Vern-MI
04-24-2007 10:41:50
Nice pix, Shep. Did you find a trailer for your BSA gear?
ShepFL
04-24-2007 11:01:13
 Re: Cutie Pie !! in reply to Vern-MI, 04-24-2007 10:41:50
Short answer - NO. Longer Answer - Work In Progress.
I was at the dump the other day and found an old pop up camper frame. I drug it home much to dismay of Mrs. ShepFL. A Scout is thrifty so me and the troop will be building one.
Thanks for asking.
ShepFL
KEH
04-24-2007 16:47:57
 Re: Cutie Pie !! in reply to ShepFL, 04-24-2007 11:01:13
Shep,
Since I have built several trailers, I will share my experience with you.
First, figure the load and trailer weight and use a strong enough axle. I recommend a 3500 lb. axle. I never was a scout, but I'm sure that camping gear is heavy. Look at trailers and axles at a TSC or Northern or a local trailer dealer. Bear in mind these trailers are built to minimum standards to keep costs down. I don't know the size of your travel trailer axle, but I wouldn't trust it if it has 4 lug wheels. 5 lug wheels with 15 inch 6 ply rating is what I would recommend.
I recommend 5 x 10 as a minimum trailer size. The only advantage to a 4 x 8 is that you can use one sheet of plywood for the floor. The 10 foot size is almost as maneuverable.
IMO a trailer should have springs, which I'm sure the travel trailer has. Some of your equipment might not like sudden jolts.
The commercial trailers at TSC, etc, have angle iron sides on them which make a truss which strengthens the frame. Assuming you are going to be making an enclosed trailer, your framework will have the same effect. Haven't built an enclosed trailer, so can't advise you, except to try and make a v shaped front to cut down on wind resistance. Don't know the size of the frame members on the travel trailer, but for a flat bed trailer with out trussed sides, 3 inch channel is adequate, 4 inch more than adequate. This for comparison.
Check the capacity of the ball hitch. Be sure it's greater than your expected load.
You will want lights. Wireing lights is another issue which depends on the model of truck, to some extent, and I'm not too good at it, except to say having a good ground is important.
Bear in mind when you make a trailer, it is my understanding you become a manufacturer and are liable if it falls apart on the road. Of course, if you have a factory trailer and you cause a wreck with it, you are still liable so I'm not sure if you are any worse off. Check local laws with insurance company.
I'm a big believer in safety chains and receiver hitches. BTDT.
We used to have some good friends from FL who traveled up here to SC from St. Pete pulling a home made trailer, also up to Maine. I think he said in FL the state required you to have a trailer tag, but you could shift it to other trailers you had. Interesting, you don't have to have trailer tags here. Good luck.
KEH
Tpost
04-24-2007 12:22:40
Great to see your partisipation in scouts. I am an eagle myself. I work long hours with odd scheduals and my son is only 3 but hope to have everything lined out before long so I can help with some outings even if I cant become a Scout Master. I hope my son is as involve as I was. Its one of the greatest organizations there is in my book. I cant remember is there a farming metit badge? Or tractor operation badge? If not there should be. Keep it up.
Jeremy in Texas (allias T-post)
georgeky
04-24-2007 14:51:25
 Re: Cutie Pie !! in reply to Tpost, 04-24-2007 12:22:40
There are several ag related merit badges. Animal husbandry,horticulture are two I can think of.
Ludwig
04-24-2007 14:14:18
I wonder how many Eagle Scouts are on this forum? I got mine in '94.
I think the merit badge would be in Agriculture or somthing like that. I seem to remember a picture of a guy on a tractor but I might be thinking of a road sign.
My favorite was Cinematography but that shouldn't be a surprise, I'm a professional videographer.
Bill in NorthCentral PA
04-24-2007 18:24:14
 Re: Cutie Pie !! in reply to Ludwig, 04-24-2007 14:14:18
1988. Wouldn't change a thing.
Mydeere
04-24-2007 18:35:48
 Re: Cutie Pie !! in reply to Bill in NorthCentral PA, 04-24-2007 18:24:14
1986 Order of the Arrow also. I earned the Farm Machinery merit badge. Don"t know if they still have that one though.
