Tractor Talk Discussion Forum
case trouble
jacob s
04-24-2007 05:00:28
I have a case tractor. I don"t know the model of the tractor. it is about 30 to 35 hp runs very well. But when I put water in the radiator it goes in to the oil. what do I do.
wilson
04-24-2007 06:57:13
 Re: case trouble in reply to jacob s, 04-24-2007 05:00:28
if it has side inspection covers on the oil pan check as d series had these and were about that size. Most likely your problem is the o rings at the bottom of the sleeve. drop pan if there are on side plates
IaGary
04-24-2007 05:08:51
That ain't good.
Start tearing the engine down till you find the problem.
Start with the head and check the gasket for bad spots.
If this just developed after the winter here, maybe the block froze and broke.
Good luck, your gonna need it.
