Tractor Talk Discussion Forum
pto -rakes
coup
04-22-2007 17:06:26
my old 1973 445 long is a good old tractor but my pto rakes pretty bad...the drive speed side does,'t rake at all,,does a now tractor rake any at all..... my old 8n use to rake and so did my old int cub lowboy.....
Hard Knocks
04-23-2007 05:03:31
 Re: pto -rakes in reply to coup, 04-22-2007 17:06:26
All Fiats of that type have the same problem.Manual acutally says to cut engine off when engaging the lever.If you have the separate
handle to control the PTO its not a problem as much you can control the PTO with the lever.
Tim B from MA
04-22-2007 19:24:17
I just finished raking the whole dang yard today, I wished I could have done it with the pto.
I have an 841. I'd apprieciate if you could give me some tips about how to get the pto on that to rake. I have a hard enough time getting my teenage boys to rake. :)
JRT
04-22-2007 19:12:02
By "rakes", do you mean grinds when it goes into gear?
coup
04-23-2007 02:53:37
 Re: pto -rakes in reply to JRT, 04-22-2007 19:12:02
thought that was pretty easy to ascertain.....
Jim Johnson
04-23-2007 07:56:12
 Re: pto -rakes in reply to coup, 04-23-2007 02:53:37
Well I'd guess you're wrong. Can you ascertain that or are you raking?
coup
04-23-2007 15:41:43
 Re: pto -rakes in reply to Jim Johnson, 04-23-2007 07:56:12
not sure what your trouble is but bout ready to make it my business where the -are you.....
IH2444
04-22-2007 18:20:14
A problem with the PTO or the Rake ?
Sounds like maybe both ?
TimWafer
04-22-2007 17:30:52
OK, Ill admit I have no idea what your asking. Please explain for us in the dark!
Gene dotson
04-23-2007 03:45:14
 Re: pto -rakes in reply to TimWafer, 04-22-2007 17:30:52
I believe he means the PTO gears grind when he tries to engage. Either the clutch drags a little or he in just not waiting long enough for the gears to stop rotating. Can't get in a hurry to engage them. Try shifting the transmission into gear when you engage the control lever.
coup
04-23-2007 15:42:43
 Re: pto -rakes in reply to Gene dotson, 04-23-2007 03:45:14
thanks.....
RAB
04-22-2007 23:22:08
Tim, I think the best chance you got is to wait for the morning when it will be light! I think he means "grates"
Regards, RAB
