Tractor Talk Discussion Forum
8n will not run ulless i 1/2 choke
gary haar
04-22-2007 08:08:48
tractor sat for 8 years new tires new carb new cap rotor oil change runs good but need to leave the choke 1/2
flying belgian
04-23-2007 03:57:20
 Re: 8n will not run ulless i 1/2 choke in reply to gary haar, 04-22-2007 08:08:48
Make sure the gas cap vent is not pluged. try removing cap and see if that helps. I had that happen on an old truck.
SAndbur
04-22-2007 19:55:20
I had the same probelm with my 9N. Found crud in the tank restricting fuel flow. I blew back on the line with compressed air to get things rolling. Ended up flushing the tank out
IH2444
04-22-2007 16:55:47
Being a "new" carb does not mean it is right....
Ken L.
04-22-2007 13:40:05
I noticed that you wrote that you have a new gas filter. The 8Ns didn't have a filter. If you installed an inline filter and it's a good one, not a Fram, it may not let the gas though fast enough. Pulling the choke out would help. Make sure that you have good gas flow.
old
04-22-2007 08:54:41
Well with a new carb it sounds like you have weak spark, by chokeing it you cover up the fact that you have a weak spark. Change the points and condenser plus install new Auto lite 437 sparks plugs
Jeff in VA
04-25-2007 14:33:19
 Re: 8n will not run ulless i 1/2 choke in reply to old, 04-22-2007 08:54:41
I had the same problem, not spark, not carburator... It was a leaky (cracked) exhaust manifold. Too much air coming in to the mixture. Just my .02
weum817
04-23-2007 05:33:31
The spark has nothing to do at all with having to choke the tractor..you are straving for fuel...fuel filter, dirt in tank or line, a piece of dirt in carb,maybe line not tight sucking a little air.... but not the ignition
old
04-23-2007 09:06:12
 Re: 8n will not run ulless i 1/2 choke in reply to weum817, 04-23-2007 05:33:31
Just to let you know Dell refers to a problem like this one today and again he says weak spark and haveing to use starter fluid to get on to run. So its up to you to have a look see and asked them whats up
old
04-23-2007 08:39:03
Normally I would agree but if you check in the ford 9N/2N/8N forum you will see it refered to all the time that weak spark and chokeing will make them run where as if you don't choke them they don't run and its because of a weak spark. Its also the only tractor I have ever seen it said about, I'm just passing on what is said there all the time. So don't shot the messeager and look in the arcive for your self and you will see what is said there
Walt Davies
04-22-2007 17:22:32
If it has a weak spark and you pull the choke out it will only run worse.
Having to pull the choke out can only mean one thing the tractor is running lean, that is a fuel problem not spark.
Walt
old
04-22-2007 18:39:46
 Re: 8n will not run ulless i 1/2 choke in reply to Walt Davies, 04-22-2007 17:22:32
Walt, common problem on the ford N series tractor is weak spark and by chokeing it that makes them run better but doesn't correct the problem. Check the arcives in the 9N/2N/8N fourm and you will see time and time again where chokeing has lead to the fact they had a weak spark. Dell is one that hammers that home about once a day if not more
Walt Davies
04-22-2007 21:31:51
 Re: 8n will not run ulless i 1/2 choke in reply to old, 04-22-2007 18:39:46
OLD unless that choke is hooked up to the advance it is physically imposable. I have been a mechanic for over 40 years and believe me I know what I am talking about.
Walt If anyone doesn't believe then I suggest they go out start their tractor warm it up then pull out the choke to half choke position an see what happens.
old
04-23-2007 08:35:54
 Re: 8n will not run ulless i 1/2 choke in reply to Walt Davies, 04-22-2007 21:31:51
Walt well if you don't believe me then I'm sorry its a fact on the N series fords, its also the only ones I have ever heard it about. What can I say other then I'm just passing on to you what is said all day long in the ford 9N/2N/8N forum.
RAB
04-22-2007 09:16:11
No Old! Don"t go telling him to do things which might not be needed until the spark quality has been ascertained - like look at it. If spark is blue and you can draw a spark something like a centimetre, there is nothing wrong with the spark quality and you do not need to potentially superimpose an extra problem on the one you have already. IF the spark is weak and yellow, it is time for an ignition system service - it could be as Old says, but equally a number of other faults.
RAB
old
04-22-2007 09:21:08
 Re: 8n will not run ulless i 1/2 choke in reply to RAB, 04-22-2007 09:16:11
Well he said it had sat for a long time and he replaced the cap and rotor but he didn't say any thing about the points. So thats why I said what I said but yes I should also have told him to check to make sure he had a good brite blue spark that would jump a 1/4 gap
Gary from Muleshoe
04-22-2007 08:12:17
 Re: 8n will not run unless i 1/2 choke in reply to gary haar, 04-22-2007 08:08:48
Clean the carb and all your lines. May also have some buildup around the screen in the settlement bowl.
gary haar
04-22-2007 08:21:06
 Re: 8n will not run unless i 1/2 choke in reply to Gary from Muleshoe, 04-22-2007 08:12:17
i have a new carb new gas filter
Gerald J.
04-22-2007 08:31:53
 Re: 8n will not run unless i 1/2 choke in reply to gary haar, 04-22-2007 08:21:06
Its not a Briggs carburetor, preadjusted and fixed. So go adjust the mixture screws for a richer mixture after you make sure there's no leaks at the manifold gasket, particularly the intake sections. Then be sure the fuel line isn't part plugged.
Gerald J.
