Tractor Talk Discussion Forum
farmallh missfire
Tony Hoff
04-21-2007 20:30:47
I have a h that is a magneto ignitioin that was converted to 12 volt it only fires and starts when you let off the start button and when it is running it cuts in and out it is worse when it is running at higher speeds
TomH in PA
04-22-2007 05:38:28
 Re: farmallh missfire in reply to Tony Hoff, 04-21-2007 20:30:47
When's the last time you changed (or filed) the points?
RustyFarmall
04-22-2007 05:20:42
A magneto is a stand alone ignition unit, totally independent of the battery. A magneto will create a spark even when there is NO battery. The symptoms you describe are indicative of a battery ignition distributor with a mis-wired 12 volt conversion.
RAB
04-22-2007 09:27:44
 Re: farmallh missfire in reply to RustyFarmall, 04-22-2007 05:20:42
Rusty, quite a few magnetos have been changed to run as coil systems. Most have an external coil wired and just use the mag as a distributor and points set-up.
Regards, RAB
RAB
04-22-2007 00:44:40
Sounds like there is not enough/any volts to the coil when cranking, and intermittently, when running. Probably a loose/poor connection somewhere and possibly no bypass circuit when starter position is selected. You don"t give enough information as to whether this problem has just arisen, deteriorating, been there since the change-over, details of change-over, etc - so only a guess at the obvious.
RAB
