Tractor Talk Discussion Forum
MM Zau issues
Newtothisgame
04-21-2007 10:03:39
I have a 50 zau and i took it out of storage last week to grade the drive way and we ran it for about 45 min at 1/2-3/4 throtle just fine then all of a sudden it just started to sputter and spit and would only run on 2 cylinders i figured its electrical cuz the next day when it was all cooled off it ran fine what would cause that points condencer any help would be nice thanks
rrlund
04-22-2007 12:02:15
 Re: MM Zau issues in reply to Newtothisgame, 04-21-2007 10:03:39
Could be some carbon or other buildup in the stems of the valves,expanding when they warm up,contracting and letting them loose when they cool. I've seen it before.
Glen in TX
04-21-2007 14:53:23
Might be condenser. After it quits immediately check for fire at coil and if none then you know it's ignition and could suspect bad coil, condenser or even bad wiring to coil. If fire then look at something else like fuel inlet flow.
