Tractor Talk Discussion Forum
Steel Hydraulic line
Jim-In-NY
04-20-2007 15:36:20
Its been a long day. I just broke a line on my IH 574 tractor with GB loader. It is a Steel Line for the down pressure on the loader arms. Does anyone know of a place where i can get custom steel lines made? I would like to stick with steel because their is a bracket that holds them all in place.
thanks for all your help
James
Jim-In-NY
04-21-2007 16:15:46
 Re: Steel Hydraulic line in reply to Jim-In-NY, 04-20-2007 15:36:20
i must not know how to use compression fittings. my first attempt is a complete faliure. i guess i will get it fixed next week. thanks for all your help and advice
james
Allan In NE
04-20-2007 17:19:03
Oh Heck,
Not an earth-shattering problem; just plumb it in with galvanized pipe.
Thousands upon thousands of loaders built this way and that old IH sure isn't gonna hurt it any.
Allan
midwest redneck
04-20-2007 16:48:11
Too bad you are not in the Flint Michigan area I could bend and flare the pieces for you, I did it for years. Call a cylinder rebuild place in your area and someone may be able to do it there, or a pump/valve rebuild place. Maybe a tractor dealer in your area may do it as well.
135 Fan
04-20-2007 17:08:38
 Re: Steel Hydraulic line in reply to midwest redneck, 04-20-2007 16:48:11
You need to find a good hydraulic hose and fitting supplier. Most hose outfits don't have the flaring tools but it shouldn't be hard to find one that does. Talk to a heavy equipment dealer. If they don't do it, they probably know who does. Dave
Midwest redneck
04-20-2007 18:35:02
 Re: Steel Hydraulic line in reply to 135 Fan, 04-20-2007 17:08:38
You dont have to use flare fittings, The compression fitting work well too as long as they are done correctly.
Don-Wi
04-20-2007 23:05:47
 Re: Steel Hydraulic line in reply to Midwest redneck, 04-20-2007 18:35:02
I agree with ya there- I have a couple line custom made for the power steering on my Oliver 1600 as the steering moter was replaced at one time. One of the lines is a rubber hose that has a compression fitting on one end that will go over a cut off steel line and make a very nice repair.
I plan on having 2 more short peices made with those connection on both side for our massye 285, which has smalle leaks in both rubber flex lines in the steering circuit. The rest is all steel, but the hose is just so it has some flex. One is spongy the other is rock hard (don't worry, squeezed it with the tractor off and no oil preasure so as not to get oil under the skin. It was also just preasure washed and degreased for an overhaul so I can see exactly where the leaks are)
Donovan from Wisconsin
