Tractor Talk Discussion Forum
OT: Condenser Capacitance Value
VinnieNC
04-20-2007 07:57:48
Does anyone know the approximate value of a condenser used on a breaker point ignition? I want to use a capacitor to dampen the arcing on a set of relay contacts so as not to burn them out too fast. I am thinking around 0.1 uF non-polarized.
Any suggestions are welcome.
-VinnieNC
MarkB_MI
04-20-2007 17:52:03
 Re: OT: Condenser Capacitance Value in reply to VinnieNC, 04-20-2007 07:57:48
Vinnie, an ignition condensor is matched to the inductance of the ignition coil. The ignition system is a crude tuned circuit. So the value of an ignition condensor is irrelevant to your problem.
As KT and KEB said, a better solution is an anti-kickback diode. KEB described the correct way to connect it; it must be connected in parallel to the load, not the relay. And it must have a very high current rating, as Gerald said. If your horn draws 3 amps, you might get away with a 1N400x, which is rated at 1 amp. If it draws 10 amps, I doubt it will last. (Of course, you'll never know if the diode is blown, unless you disconnect it and test it!) You can get 3 amp silicon rectifier diodes (e.g. 1N5402) with axial leads that are a better choice.
Really, if you have a sufficiently big relay, you don't need to worry about arcing. After all, your starter relay routinely handles several hundred amps, and you don't see capacitors or diodes hanging off it. Also, I think the current through a horn is basically ac (pulsed dc, to be correct); if you look on most switches and relays you'll find that they have much higher ac ratings than dc, because ac interrupts itself.
Glen in TX
04-20-2007 13:21:52
I read on down you were using it with a horn relay. Was thinking someone made a breaker relay to wire in with those that probably has a capacitor or diodes already in it. Take a look at horn relays in the Cole Hersee catalog colehersee.com or see what they carry at a HD truck parts place as most of them carry that brand. Just wanted to add when you are trying to decide on voltage rating for a capacitor like a ignition system for example I use capacitors in magnetos with a 600V rating at least. 250-300V will work but to make it last you double the voltage rating on it. You shouldn't need that high a rating for a horn relay though.
jdemaris
04-20-2007 11:23:21
 Microfarad ratings in reply to VinnieNC, 04-20-2007 07:57:48
Battery igntion systems usually use a condensor rated .20 to .28 microfarads. Magneto systems usually .16 to .20 micorfarads except for a few exceptions, e.g. Wico XHD use a .35 MF condensor and a Case 4JMA uses .40 MF.
KEB
04-20-2007 10:28:47
Vinnie,
A better, more commonly used approach is to use a diode as a "back-emf" suppressor on the load you're switching. Simply connect a rectifier diode, like a 1N4004 or something similar, across the load (not across the contact points), with the banded end connected to the positive side of the load and the non-banded end connected to the negative (grounded) side. If you really want to use a capacitor across the contacts, any disk capacitor in the 0.01 to 0.1 uF range would work, but in general its better to suppress the source rather than try to protect against possible effects.
The inductive "kick" from switching an inductive load is always the opposite polarity of the applied power, so the diode shorts the inductive spike but does not normally conduct.
What you're trying to do isn't quite analogous to a kettering ignition. Here, you want to suppress the effects of the back emf spike. In a kettering ignition, you want to use that spike to make a spark in the cylinder. In addition to limiting wear on the points, the condenser in a kettering ignition is part of a resonant circuit which "rings" when the points open, resulting in a hotter spark than you would get from the collapsing magnetic field in the coil alone.
Do a web search on "back-emf suppression" for more information than you'll ever be able to use. Actually, I seem to recall automative horns coming with suppression already installed, but can't be sure.
By the way, the comment below that a current surge will cause a capacitor to explode is not true. What typically damages a capacitor is a VOLTAGE spike high enough to puncture the dielectric material between the capacitor plates. Once this path is established, how much current flows depends on how much current is available from the source of the voltage spike; if the source impedance is low enough, it may be possible to drive enough current through the capacitor to cause it to overheat and rupture. It is possible to overheat a capacitor by trying to force too much alternating current through it, but this generally requires a sustained current source, not a surge.
Keith
KT in NE
04-20-2007 10:11:43
Use a diode instead. Hook the cathode(the end with the stripe) to the side of the relay contact that goes to +12, and hook the anode(the end without the stripe)to the side that goes to the horn. That will work better than a capacitor.
You can get one at Radio Shack. It would be a general purpose 1N4001 up to 1N4007 diode.
Gerald J.
04-20-2007 10:55:56
 Re: OT: Condenser Capacitance Value in reply to KT in NE, 04-20-2007 10:11:43
A 1N400x diode across a 15 amp horn is going to go POP the first time the horn button is released. To do any good with a diode it needs to handle 15 or 20 amps.
Gerald J.
KEB
04-20-2007 16:51:08
 Re: OT: Condenser Capacitance Value in reply to Gerald J., 04-20-2007 10:55:56
Nonsense. The horn current does NOT go through the diode, only the transient current resulting from the collapsing magentic field in the inductor when the main circuit is broken. Diodes have been used across inductive loads to suppress transients ever since solid state electronics became common.
Keith
Gerald J.
04-20-2007 09:26:04
Use a relay with ample sized contacts and that open good, helps to be rated as a horn relay.
Gerald J.
VinnieNC
04-20-2007 09:02:03
Thanks gentlemen!
I should have added the other details. I am wiring a 12 Vdc car horn through a relay and want to get as much life from the relay contacts as possible.
It's a shame tractors don't have a horn as "standard" equipment!
-VinnieNC
Walt Davies
04-20-2007 08:35:53
Using a Condensers on a system with several hundred Amps would result in one big bang as they explode from the surge.
Talk to your electrical supplier and see what they use on there large switches.
Walt
Bob
04-20-2007 08:15:13
.025 mfd is a common Kettering ignition system capacitor value.
What are the relay contacts powering... a large inductive load?
Bob
04-20-2007 12:30:21
 CORRECTION... in reply to Bob, 04-20-2007 08:15:13
jdemaris is correct. An extra "zero" crept into my other reply. (Yeah, THAT'S IT... crept!)
Typical battery ignition condensor capacity is .25 mfd.
