Tractor Talk Discussion Forum
Ford 3400 industrial serial number location
Rapitrone
04-17-2007 10:07:29
We have Ford 3400 industrial and we can't find any sign of a serial number tag. where is this located?
Van in AR
04-17-2007 10:46:57
 Re: Ford 3400 industrial serial number location in reply to Rapitrone, 04-17-2007 10:07:29
There is a tag on the under side of the hinged right hood and also the serial number is stamped on the block by the starter, the tag has more info as transmission type and rear end type
Ultradog MN
04-17-2007 10:57:04
 Re: Ford 3400 industrial serial number location in reply to Van in AR, 04-17-2007 10:46:57
Van,
You're close...
The serial # is stamped on top of the Tranny not the block - on a flat spot just behind the starter.
Rapitrone, I've got a 3400 that I'm parting out if you are needing something...
