Tractor Talk Discussion Forum
OT: two stroke engine on rototiller
Tim, Ohio
04-16-2007 17:34:14
Hello Everyone,
If you do not mind, I would like to ask for help with a small two stroke engine that drives
the tines on my Mantis tiller. I am frustrated
because I cannot get it to run with any power.
I cleaned up the plug, regapped it and put back
in place. I then emptied all of the old gas out
and refilled with new gas and oil (50:1). I then
adjusted the carb, following the manual instructions. I can get it running and it idles
well. When running I sprayed carb cleaner in the
carb to clean it up. The problem is that the adjusting screws on the carb seem to do nothing
when they are adjusted. When I go to throttle
the engine it has no power. I cannot get a smooth transition to full throttle without hesitation, then stalling. What would you guys
do? I am about to tear apart the carb and
see about cleaning it up. It seems like all of the small engines I have ever had only run
well for a couple of years (except chainsaw engines, which seem to run and run) then go south.
Thanks for any tips.
Tim, Ohio
davpal
04-16-2007 21:39:02
 Re: OT: two stroke engine on rototiller in reply to Tim, Ohio, 04-16-2007 17:34:14
You have a fuel restriction and cleaning the carb should do the trick. Probably has a little jet in there plugged up.
jokers
04-16-2007 18:37:50
My dad has a Mantis that was doing the same things that you describe. I took the carb off and gave it a thorough cleaning. It runs like new now.
IA Roy
04-16-2007 18:14:26
I have an 8 to 10 year old Poulan Pro saw and had a similar problem. As mentioned above, I took the mixture adjustment screw caps off and adjusted the power screw so that it had some powerl
Moe Joe
04-16-2007 17:58:21
I believe the mixture screw(s) may have limiters installed over them. Sometimes if you remove them you can get enough richening to clear things up, if not, it may require carb work.
The Echo motors had a gas cap vent arrangement that didn't do well with todays gas and can become glued shut.
You might check, or change the fuel filter in the tank.
Matt Kane
04-16-2007 17:56:37
I have had this happen to me almost every year. Look at the hole on the muffler, and more than likely its plugged. Those mud dobbers like to make their homes in the mufflers. Poke something into there to clean it out. Hope this helps.
Wild Bill
04-16-2007 17:56:35
The muffler stopped up, or more likely the air filter stopped up
frankiee
04-16-2007 17:53:26
I would take a look at where the crank comes out of the engine and drives the chain. Look for signs of leakage. A wet spot.
When it is working. Spray some carb cleaner where the crank goes in the engine.
I say that because could be the crank seal is leaking and admitting air into the crank.
hlc
04-16-2007 17:50:43
Carbon in the port holes under the muffler can cause loss of power.
Gordon Stenke
04-16-2007 17:45:40
Take the muffler off, it probably has carbon bult up jn it.
