Tractor Talk Discussion Forum
OT: Sea Foam did the trick for my Outboard
Hec In Omaha
04-16-2007 08:24:19
Howdy all,
I have 2001 Honda BF30 four stroke outboard. The motor sat 1-1/2 years without the 3 carb bowls being drained. I screwed up the last time the boat was winterized. I put the boat in the water and the engine fired right up. Allthough it started ok it never would develop full power under load. I could never get the boat to plane out. I added a can of Sea Foam to the 6 gal tank and just let her run on my lift all day. Yesterday I took out the boat and she ran great. The stumbling of the engine was gone! That stuff is amazing. I am a believer.
Hec
Wild Bill
04-16-2007 08:45:30
 Re: OT: Sea Foam did the trick for my Outboard in reply to Hec In Omaha, 04-16-2007 08:24:19
Sea foam is EXCELLENT for what it designed to do. You should try the "shock treatment" to clean out the carbon in your cylinders. Directions are on the can.
Leland
04-16-2007 18:53:00
 Re: OT: Sea Foam did the trick for my Outboard in reply to Wild Bill, 04-16-2007 08:45:30
just unhook a vac line suck a can into intake shut off engine and let it soak for a while
