Tractor Talk Discussion Forum
IHC Super M
Wayne Rogers
04-16-2007 06:37:55
I just bought a Super M. 1953 I believe, serial 48423. It came with a Farm Hand Loader.The Pump for the loader runs off the Power Take Off. I believe this tractor has live hydraulics as the pump for the Lift All is mounted on the Engine in front of the Dist. Would this pump be big enough to operate the loader if I hooked it direct?
David in Wales
04-16-2007 09:09:34
 Now I know why .... in reply to Wayne Rogers, 04-16-2007 06:37:55
Hey Allan;
At last I've figured out why you need so many loader tractors. You've used them to push over the trees and level the hills off to make those nice flat fields that you farm ! LoL
Cheers David
Allan In NE
04-16-2007 07:14:22
 Re: IHC Super M in reply to Wayne Rogers, 04-16-2007 06:37:55
Yep,
However, you'll loose a little loader speed doing it that way.
Allan
third party image
Allan In NE
04-16-2007 08:26:09
 Re: IHC Super M in reply to Allan In NE, 04-16-2007 07:14:22
I should clearify that a bit.
If you also use the live pump for power steering in conjunction with a priority valve, it will indeed cut the loader's speed.
However, if you're using the live pump solely for the loader alone, it doesn't seem to affect it all that much.
Allan
ejr-IA.
04-16-2007 07:03:04
Yes with a oil supply and remote valves for the loader.
Wayne Rogers
04-16-2007 13:23:45
 Re: IHC Super M in reply to ejr-IA., 04-16-2007 07:03:04
Thanks to all for the replys. The tractor does have power steering on it. I will mainly be useing the loader to raise Windmill Towers. I like old Windmills also.
