Tractor Talk Discussion Forum
diesel fuel
plowboy1
04-15-2007 18:41:41
I have a couple of older diesels that we run here around the farm. I've read that the new re-formulated diesel has very poor lubricateing properties. What can I add to protect the fuel pump and injectors? Been using Marvel Mystery oil but after checking it out more thoroughly, it seems more of a detergent than a lube. Thanks
MN Scott
04-16-2007 20:33:00
 Re: diesel fuel in reply to plowboy1, 04-15-2007 18:41:41
If you buy good quaility clean diesel from a honest dealer you do not need an additive in any diesel engine. Your just trowing good money away. The only time you may need an additive is if you have water in your fuel tank and have alge growing, then use an algeicide. Same thing in the winter if you run the proper blend you do not need an additive. Several years ago the local CIH dealer sold dad a bottle of power service in the winter. The dealer said use this and you don't need to blend fuel. I told dad he had wasted the money as it would not work. Well a few days later it was -10 and he was going to dump it in the loader tractor. The stuff would not even pour out of the bottle! So save yourself the problems you might create from dumping snake oil in the fuel system and put the two cycle oil in your chainsaw and buy quaility fuel and don't worry about it.
Allan In NE
04-16-2007 07:36:12
Feel honored 'cause you're witnessing the birth of another old wives' tale. :>)
Allan
mjbrown
04-16-2007 05:54:12
If you're concerned you can add two cycle oil,ATF, or any number of other clean oils. Your older diesels are quite tolerant .
RustyFarmall
04-16-2007 04:27:27
It is the responsibility of your fuel supplier to ensure that his product meets the demands of your engines. Ultimately, if your engines fail because of fuel related issues, your fuel supplier has to stand the cost of making the repairs. Additives are just money down a rat hole.
Gene Dotson
04-16-2007 03:44:52
Plowboy;
There will be dealers and stations in your area who sell off-road diesel. This fuel still has the sulpher in it and is not subject to paying road taxes. This is only for off road use and cannot be used in trucks used on the highway.
For my Dodge truck, I am using 2 cycle oil when i add fuel. Dollar stores usually have the small 2 cycle bottles for a buck each and I keep them in the seat of the truck and add one each time.... Gene
paul
04-15-2007 18:55:05
Along the same lines, 2% or so of bio-diesel (typically soybean oil but from any of the oil crops....) does it. Minnesota has 2% in all the diesel fuel.
--->Paul
Plowboy1
04-16-2007 18:00:23
 Re: diesel fuel in reply to paul, 04-15-2007 18:55:05
Thanks boys for the information! I have started the 2 cycle oil but wasn't sure if it would help, now I feel a little better about it. Try to get a fuel company to pay for repair? I can just hear thier speil; " you got proof/" "how old is it?" "you didn't get that fuel from us!". From what I've read (not just internet stuff) bio-fuel has excellent lube properties but is very pricey in my area. Course once you figure in the price of additives, ya,it is pouring money down that old rat hole! Thanks agin'
Sunny 4 acres
04-15-2007 18:47:41
 One cup of canola oil in reply to plowboy1, 04-15-2007 18:41:41
Add 1 cup of straight unused canola oil to everytank full of diesel. I have done this for a long time and never had any problems with injection pumps. On the net somewheer it is said to increase lubrication by over 60%. One cup of canola oil to every tank full of gas!
4010guy
04-15-2007 19:38:45
 Re: One cup of canola oil in reply to Sunny 4 acres, 04-15-2007 18:47:41
When you say tank full do you mean like a 35 gallon tractor or service tank?
Zach Mignot
04-15-2007 19:33:40
So what is it to gas or to deisel ? You said both so is it both ?
Sunny 4 acres
04-15-2007 21:22:25
 Re: One cup of canola oil in reply to Zach Mignot, 04-15-2007 19:33:40
Yes I do it to both. Gas and diesel
Just wondering
04-16-2007 17:28:30
 Re: One cup of canola oil in reply to Sunny 4 acres, 04-15-2007 21:22:25
What would be the purpose of adding canola oil to gas (unless you are talking 2-cycle mixed gas). Seems to me in a newer car you'll do more harm than good (premature contamination of O2 sensor etc etc).Just wondering
