Tractor Talk Discussion Forum
coffee in hydr
Duane TX
04-11-2007 15:27:50
The hydr. fluid in my tractor is coffee color.
Does this mean I have water in it????
Dave Anderson
04-12-2007 16:05:58
 Re: coffee in hydr in reply to Duane TX, 04-11-2007 15:27:50
Whatever you do, don't put hydraulic oil in your coffee, it'll give you the trots.
Allan In NE
04-11-2007 16:27:56
Yep, it are.
I use diesel fuel to clean 'em up. Fill 'er about 2/3 full and run 'er around the yard for 10 or 15 minutes.
Pull the plug(s), let it drain and drip overnight. New filter and oil and you're good to go for another season or two.
Allan
Michael Soldan
04-11-2007 16:22:17
..its a no Brainer..you got water!
San Jiah
04-11-2007 15:53:18
Maybe, maybe not,
send a sample in for analysis.
Donnie Baker
04-11-2007 15:30:54
If it looks like coffee w/cream then yes you have water. I gotta go
Jon Hagen
04-11-2007 17:08:29
 Re: coffee in hydr in reply to Donnie Baker, 04-11-2007 15:30:54
Brown oil may mean rust from water, although some hydraulic oil has a natural brown color. One trick to identify water in oil is to pull the dipstick and drop a bit of it on top of a hot exhaust manifold of a running and warmed up engine. Pure oil will just flow out and smoke, oil containing water will develope little steam bubbles in the oil, as the water boils on the hot manifold.
Gene-WI
04-11-2007 18:22:39
 Re: coffee in hydr in reply to Jon Hagen, 04-11-2007 17:08:29
That sounds like a very smart trick, I'll have to give it a try.
IH2444
04-11-2007 20:07:15
 Re: coffee in hydr in reply to Gene-WI, 04-11-2007 18:22:39
Yes when I use old water laden Hydroi oil to burn brush it pops and crackles from the water in it, non water contaminated oil does not pop.
I have not tried that test, but it should work.
Jon Hagen
04-11-2007 23:15:16
 Re: coffee in hydr in reply to IH2444, 04-11-2007 20:07:15
The same "hot manifold" test works if you suspect coolant in your engine oil. That hot manifold is well above the boiling point of a 50/50 water/antifreeze mixture, and you will see the same little steam bubbles in engine oil contaminated with antifreeze coolant.
