Tractor Talk Discussion Forum
350 B JOHNDEER DOZER
driggersfarm
04-08-2007 13:45:08
I'M LOOKING AT 1987 350B JOHNDEER DOZER DIESEL,
ANYONE KNOW THE HORSE POWER OF THIS TRACTOR AND
TRACTOR HAS BEEN RESTORED AND IS IN GOOD CONDITION WHAT IS A GOOD PRICE FOR THIS MACHINE.
JMS/MN
04-09-2007 08:29:36
 Re: 350 B JOHNDEER DOZER in reply to driggersfarm, 04-08-2007 13:45:08
I've been dozer hunting for a couple of years, want a Cat, but found this on JD 450, should be parallel for the 350: 450 made in 1965, B series 69-73. They had dry clutches. C series 1973-84, D series 84-87. They had wet clutches. Weakness? Check transmission housing for cracks. Loose bolts and wear on frame lets the tranny twist. Steering clutch/brake adjustment is critical to prevent burnout.
jdemaris
04-08-2007 17:18:32
You better double check the year - that does not sound right, not even close. We sold 350Cs new - late 1970s as I recall, and a B has to be older. A 350B can have either the 152 engine at 39 horsepower or the 164 at 47 horsepower.
DRIGGERSFARM
04-08-2007 17:37:13
 Re: 350 B JOHNDEER DOZER in reply to jdemaris, 04-08-2007 17:18:32
THANKS'I WILL CHECK, IS THERE ANY WEAK POINTS
ABOUT THESE DOZERS.
2x4
04-09-2007 23:55:07
 Re: 350 B JOHNDEER DOZER in reply to DRIGGERSFARM, 04-08-2007 17:37:13
the winch, if it has one, is the strongest point. The rest of it is a weak point.
