Tractor Talk Discussion Forum
O/T just for your info
old
04-07-2007 13:01:59
A friend called me a little bit ago. He said he was haveing trouble with his truck. 200? GMC, well any how he said all his lights and gauges where going crazy and when he tried to start it nothing. Well I told him to check has battery cables so he said I will and hung up. Well he called back about 15 minutes later and said well you where right the cables where loose. Goes to show how something so simple can cause big problems. Just saying this because it might help some one else down the road some time
Walt Davies
04-07-2007 21:59:07
 Re: O/T just for your info in reply to old, 04-07-2007 13:01:59
Darn I was sure it was Alians from outer space.
Walt Remember Close Encounters
NC wayne
04-07-2007 17:58:15
Friends crew brought his truck in the other day with the transmission not shifting right as well as several other seemingly nonrelated, non driveline related problems. he called several guys who routinely work on that type of truck and on their advice replaced a $30 speed senser in the rearend. That didn't fix the problem so he started looking on his own. Turns out there was a fuse that powered the speed senser, the dome light and several other things and you guessed it, it had blown. Man he was sick that he had spent $30 over a 10 cent fuse...
david from mo
04-07-2007 19:26:52
 Re: O/T just for your info in reply to NC wayne, 04-07-2007 17:58:15
Okay I'll bite . What truck are we talking about? Dome lite fuse should be hot key off, any driveline fuses would have key on for current.
vitzarus
04-07-2007 14:26:52
Probably does Old. Funny thing is I was just puttin a tach in an old economy truck and since I had to go further and further into the dash to wire it right I took off a cable so I wouldn't burn it up if I shorted something. Well sure enough there was corrosion on the post and connection. So I think about this. There was no indication earlier but it's a simple '80's truck. This stuff could mess up the computer ones from late '90's.
