Tractor Talk Discussion Forum
PHOTO - big plow
David in Wales
04-06-2007 12:45:23
third party image
Hi Gang;
Whilst in the NH dealers in Shropshire saw this secondhand BESSON 7 furrow reversible plough.
Yes it needs the board geasing up ! The implement behind is a packer-roller.
Cheers David
Armand Tatro
04-07-2007 12:57:43
 Re: PHOTO - big plow in reply to David in Wales, 04-06-2007 12:45:23
David: What size are those plow bottoms (furrows); 14; 16; or 18 inches? Also I don't think that packer is attached to the plow. Armand
NothinbutaCAT!!
04-07-2007 11:57:51
yall think thats big, you should see what i rigged up a few years back, a 1975 D8K hooked up to a 14 inch 24 bottom plow its 2 old 12 bottoms i hooked together. you wanna talk about makin a D8 grunt!! its all she has to pull it in the heavy ground. Biggest day was 200 acres!
Glen in TX
04-06-2007 18:37:59
Wow it does look longer in the the hitch area. A local welding/machine shop here made some 9 bottom roll over plows of their own frame design but using JD shanks and bottoms. Amazingly those plows still bring good prices at auctions today when changing hands again too.
MNredfarmer
04-06-2007 17:36:05
I always thought it was funny how there is all this heavy iron on the hitches of these plows--- and a 1 inch bolt that takes all the pull. We have a 8 bottom Oliver pull type plow and the hitch hooks to the plow with one 1" bolt. Funny thing is that I've pulled the hitch off twice and the bolt isn't the weak link.
phillip d
04-06-2007 16:22:19
our neighbours run a plow like that,only theirs has a trailing wheel!holy crap,they pick that thing clear up off the ground?
JoeBob/IN
04-06-2007 14:58:48
I can't imagine the stress on the toplink with that long of a plow! Even with a large 4-WD I don't think I would attempt that one.
RayP(MI)
04-06-2007 13:54:06
That looks like it'd take a fair tractor just to pick up and transport!
davpal
04-06-2007 21:13:33
 Re: PHOTO - big plow in reply to RayP(MI), 04-06-2007 13:54:06
You think that plow looks heavy, how much do you think that packer in back of the plow weighs? They must have some strong 3 point hitches.
