Tractor Talk Discussion Forum
1466 platform
IH1466
04-06-2007 12:10:44
Hi, I just purchased a IH 1466 tractor at an auction with a cab and i plan on taking it off and put fenders on. Does any one know what operator platforms will fit a 1466. I assume all the 66 series floors will fit on the 1466. Will any other ones fit such as say one from an 806. Thanks for your help in advance.
Allan In NE
04-06-2007 13:28:25
 Re: 1466 platform in reply to IH1466, 04-06-2007 12:10:44
766 and up open station will fit and the open station platform is totally different than the cab platform.
Additionally, battery trays, PTO lever, battery heat shields and wiring are all different.
Don't care what anyone says; been all thru this. :>)
Allan
1466IH
04-06-2007 14:53:35
 Re: 1466 platform in reply to Allan In NE, 04-06-2007 13:28:25
Thanks for everyones help!!!
dhermesc
04-06-2007 14:49:50
Agreed, the cab platform is differant (smaller if I recall) then the open station platform. You might "make it work" but you won't like it.
Been through it too helping my brother swap them out.
mike tego
04-06-2007 12:42:11
the platform does not come off with the cab all you will need is fenders, that if it is a 66 not 86
Ron 1456
04-06-2007 12:40:51
The platforms on the 56 and 66 tractors were pretty much the same (756-1566). The 06 platforms were a little different. You can probably just use the one that is on it after you take the cab off. You can go to the CaseIH web site and do some research in the parts section. 56 tractors that had factory cabs used a different platform than the ones with fenders. However the cab platform will work with fenders.
04-06-2007 12:39:59
Jim Johnson
04-06-2007 12:36:03
Call Elmers Repair 785 857 3248 he can tell you all you need to know and will have the parts too. Good people to deal with.Jim
