Tractor Talk Discussion Forum
air bubbles keep getting in fuel filters
francis pawelek
04-05-2007 19:41:24
at first my 404 motor was running excellent,but would shut down from time to time,each time i'd start up and get going,it would clear out and run good,but now after all air is out of the 3 filters,and i start it up,it seems air bubbles start building up in the tops of the filters,does anyone know where this is coming from?it slowly kills the motor after a while too
ps,,,anyone know where i can get a john deere 404 motor injector tightening wrench?
Tx Jim
04-06-2007 02:34:48
 Re: air bubbles keep getting in fuel filters in reply to francis pawelek, 04-05-2007 19:41:24
Possible pin hole in line from tank to lift pump. Air will be pulled in but fuel won't leak out. BTDT,Tx Jim
RayP(MI)
04-06-2007 14:15:06
 Re: air bubbles keep getting in fuel filters in reply to Tx Jim, 04-06-2007 02:34:48
Like Jim Tx, I have had the same problem. spent lots of time finding and dealing with leak. Even when I found and fixed pinhole, there was a problem. Finally had to replace intake tube in tank, which feeds thru a port on top of tank, typical automotive system. "bout drove me crazy. that air is coming in somewhere!
FRANCIS PAWELEK ,ALICE TE
04-06-2007 10:47:18
hi jim many thanks,but it was the tank not letting enough fuel out,,,check out my jd 7020 on thisd site,it has the 12 tires
ben brown
04-05-2007 19:48:17
the mechinal lift pump is bad eventhough its pumps fuel if your are getting air in filter it need to be changed
04-06-2007 10:45:50
 Re: air bubbles keep getting in fuel filters in reply to ben brown, 04-05-2007 19:48:17
hi ben it was not letting fuel outa the tank quik enough,i blew it out,thanks for being there on top of things though,,,also check it out on this site,,,,its the jd 7020 with 12 tires
francis pawelek
04-05-2007 20:45:33
hi ben ,my tractor has an electric fuel pump,its working right ,but i'm starting to think that i've got a tank opening to the fuel pump is stopped up possibly,acts like its running out of fuel in the filters before the pump fills em up,what you think sir
francis pawelek
04-06-2007 10:42:43
 Re: air bubbles keep getting in fuel filters in reply to francis pawelek, 04-05-2007 20:45:33
hi thanks,the trouble was from the electric pump back,fuel tank drain was stopped up
Bob
04-05-2007 20:52:05
What model tractor?
You can take the fuel cap off; then take the line off of the pump and blow compressed air back to the tank; if you think the line may be restricted.
Rex in Australia
04-06-2007 02:34:15
 Re: air bubbles keep getting in fuel filters in reply to Bob, 04-05-2007 20:52:05
Do you use a stick to check the fuel level? Check the pickup from the tank. Found that a few times on trucks, line was plugged with bits of wood and the pump sucked air in to the lines which ended up in the filters. Nearly always, I found that the fuel guage was not working and the owner was using dirty sticks to check the fuel level.
God Bless,
Rex
