Tractor Talk Discussion Forum
PHOTO - I've bought it !!!
David in Wales
04-05-2007 02:31:44
third party image
Hi Gang;
Well poverty starts here ! I've bought this 3930 at $11,700 inc sales tax. The dealer is going to replace the broken lower left window, missing mirror, bent right leveling lift shaft & plow light in the deal. I have to get the left & right side cab trim & cloth seat cover which is damaged (company here makes them now for most older tractors). Also the air cleaner top is bent & welded; the exhaust should straighten back upright with some heat & gentle force with a round bar up the lower tube.
It will be fitted with its original unused front & rear wheels & tyres.
It wont be available for 4 to 5 weeks until the terra tyres arrive from the USA for the new tractor the guy has ordered. Keep you posted with developments & photos on correct wheels shortly.
Cheers David
RayP(MI)
04-05-2007 12:13:11
 Re: PHOTO - I've bought it !!! in reply to David in Wales, 04-05-2007 02:31:44
David,
You"re going to have too much fun with that!
Good luck!
Turke Bros. Farms
04-05-2007 11:39:58
David, is that 4x4 or those baloon tires on there to keep the front end up in wet ground?
Badly Bent
04-05-2007 11:32:31
Congratulations!!! Keep us posted on further developments.
Rick Kr
04-05-2007 10:36:49
Wow, makes my 3930 tires look small.
From your post sounds like you are going to the original ag tires?
What do they use floatation tires like that for?
Rick
1936
04-05-2007 07:33:23
Would have liked to pulled dounuts on ice with the fat tires. A lots of cowboys have had a go on your new rig check the bottom of the rear end for little items. Show an action picture in the field when under pull. Could not see a cab on the yellow combine shot.
Rich Va
04-05-2007 06:31:51
Enjoy your new tractor. Send us a photo after you add the new tires and get it all shined up. My next tractor will have a cab but it will be green.
Pajamafied John
04-05-2007 06:21:36
Good for you David!! The hard part is waiting until it comes home so you can play.
Hendrik
04-05-2007 03:21:49
Congratulations on your purchase!
Will make a fine hauling tractor for you.
You may need to replace the front wheel bearings since the wide front rims and tires subject the individual bearings to greater loads than with narrow tires. A positive factor, however, is the soft ride provided by the wide tires, which lessens the peak forces. IMHO. Please, let us know what you find.
Hendrik, from The Netherlands
