Tractor Talk Discussion Forum
Off Topic Truck repair question
Sickly Ford
04-03-2007 17:07:01
I have a 1994 Ford F 150 with a 302 and automatic. When the engine gets warm it will bog down under acceleration for a few seconds (up to 20) before it will pick up and take off. Sometimes it backfires through the intake plenum while it is in this bogged down condition. Is this some type of EGR problem? The EGR valve was replaced but it did not help.
jhill52
04-03-2007 20:10:42
 Re: Off Topic Truck repair question in reply to Sickly Ford, 04-03-2007 17:07:01
Check fuel pressure and replace filter. Also check IAC 9Idle Air Control valve. It affects acceleration and idle.
davejoe
04-03-2007 19:46:57
pull the codes, is the check engine light on? Check the vac hose to the map sensor, and check the voltage at the throttle pos sensor. If you need specifics repost Dave
traper
04-03-2007 19:41:08
Check fuel filter and fuel pressure if fuel pressure dose not increase on acceleration fuel reg. or fuel pump is bad.
KEB
04-03-2007 19:10:16
Carburetor or fuel injection? If its a carb, agree that the accelerator pump is the first place to start. Take the air cleaner off, look down the carburetor bore, open & close the throttle a couple time, & see if its pumping gas into the carburetor throat (the jet will be above the throttle plate). Backfiring through the carb indicates its running extremely lean at that time. Does it do the same thing if you accelerate very gently?
Keith
roger roland
04-03-2007 20:29:37
 Re: Off Topic Truck repair question in reply to KEB, 04-03-2007 19:10:16
get real on a 94 ? wasnt it all fuel injected by then i mean your askn to check carb ? im not a ford guy but even ford would be injected by 94 or are they really dumber than i thought
OK-AL
04-03-2007 18:52:41
Could be a bad accellerator pump on the carb.
OK-AL
husky
04-03-2007 17:14:06
check for a vacuum/intake manifold leak had one several years ago caused all kinds of problems
