Tractor Talk Discussion Forum
Sealing Head studs white 2-155
md83
04-02-2007 19:27:50
i have been overhauling a d5000 Hercules in a white 2-155. I removed the head studs in the block and cleaned the threads with a tap. Then i reinstalled the studs and used a high temp thread sealer and let it cure for 72 hours and i still have the problem of water leaking out the stud bolts on top of the head when i apply 7 psi to the cooling system i still have water coming through the head studs.
rrlund
04-03-2007 10:17:04
 Re: Sealing Head studs white 2-155 in reply to md83, 04-02-2007 19:27:50
??? Do those bolt holes go in to the water jacket? Sounds like a head gasket problem or cracked head if not.
md83
04-04-2007 07:58:56
 Re: Sealing Head studs white 2-155 in reply to rrlund, 04-03-2007 10:17:04
Yes bolts go into water jacket. Head was gone through and checked by a machine shop and all valves replaced.
