Tractor Talk Discussion Forum
Windmills
Youngfarmhand
04-01-2007 18:56:48
Was researching windmills that produce electricity for home use, and was wandering if anybody had any experience with one or heard of a manufacturer. Any knowledge or thoughts about this would be appreciated.
Kent in KC
04-03-2007 05:54:39
 Re: Windmills in reply to Youngfarmhand, 04-01-2007 18:56:48
Check out the Southwest Skystream. Inexpensive, compact, built in inverter. Gotta have wind.
buickanddeere
04-02-2007 07:28:30
Link
Thse low maintenance units use PM generators and no slip rings. The 59" models spin fast enough that gear boxes, belts or chains are not required. The grid tie invertors work well. Now that utilities must allow "net metering". You will need several tubines to be worthwhile. Which wind zone are you in.
Stumpalump
04-02-2007 06:35:02
I went to a national convention for alternative power this year hoping to gather info on solar wind and passive solar construction. This was supposed to be the big deal and it was in Colorado. You should have seen the groups of dead beat,pot smoking skank that showed up as venders and participants. The Vendors had no clue as to how any of it really worked, so I would sugest dealing directly with a manufacturer. The industrie is loaded with nut jobs and those wanting to make a fast buck so beware.
Oldmax
04-02-2007 04:47:54
Try this Web Site Link This is a kit to build yourself .
Walt Davies
04-01-2007 21:16:13
Unless you live in an area that has a steady 10 knot wind most of the time its not cost effective. that 9 out of 10 days a year or more.
Walt
centralilbaler
04-01-2007 19:08:04
Here's something that i've been looking at
http://www.bergey.com/
504-2
04-01-2007 19:28:52
 Re: Windmills in reply to centralilbaler, 04-01-2007 19:08:04
There is a guy in Pittsfield IL that has one up and is selling them. He was on the local news awhile back try a Google search
