Tractor Talk Discussion Forum
(OT) Dodge 2.5 engine
RMinVA.
03-28-2007 17:39:02
Just droped the carriage to pull the engine and transmission from the wifes Caravan. It's a 1990 and has 233,000+ miles on it. Been a great little van.
When I got the transmission off I could turn the flywheel and the engine didn't turn. Found the center of the flywheel was broken out but end plate with bolts was still holding the flywheel on.
Also saw the flywheel move back when pulling the transmission off. The input shaft splines on the transmission closest to the front tranmission seal show some wear. It looks like the converter has been moving/walking in and out on the shaft.
My question is can the crank shaft in the engine be moving in and out to have caused the flywheel center to break out? It looked to be more than 1/4" that the flywheel moved back when taking the transmission off. It was getting late when we pulled it apart and I haven't checked for end play in the crank. But after thinking on it a bit and seeing the spline worn the crank came to mind.
Vern-MI
03-29-2007 05:05:46
 Re: (OT) Dodge 2.5 engine in reply to RMinVA., 03-28-2007 17:39:02
The "Flywheel" is actually called a flexplate and it serves to not only transmit torque but to allow the converter to balloon as it is pressurized. This ballooning moves the converter impeller hub into the transmission and also forward towards the engine. The engine crankshaft has a thrust bearing to absorb fore-aft movement of the converter ballooning. The transmission has a pump with two drive flats in the pump gear and the conveter impeller hub has the mating flats which drive the pump.
Replace the flexplate and be sure to use the spacer/washer that the bolts pass through. The flexplate and spacer are indexed to the crankshaft by an offset hole in the bolt circle. Make sure you have the correct replacement flywheel as it has counterbalance weights specifically for your application.
Also replace the front seal on the transmission and either replace the converter or polish the impeller hub so it will not leak at that front seal area.
RMinVa.
03-29-2007 07:14:51
 Re: (OT) Dodge 2.5 engine in reply to Vern-MI, 03-29-2007 05:05:46
Thank you for your reply. It answered a lot of my questions.
