Tractor Talk Discussion Forum
ATTN-jdemarris/ John Deere 2010
DeereDiesel
03-27-2007 19:05:54
thanks for the help on the 2010 point and plug gap. I have another question, i have the tractor hot wires. i have a jumper wire from battery to the coil. it doesn;t have a switch. i just touch two wires together. will this not make it run. The longest ive got it to run is about 12 second for the first time in 7 years. i lost the switch, how expensive are they?. Its only wanting to run on the fuel i spray in the intake to. and its likes to foul plug. whats my problem? Thanks for all the help!!
jdemaris
03-28-2007 05:40:56
 Re: ATTN-jdemarris/ John Deere 2010 in reply to DeereDiesel, 03-27-2007 19:05:54
It should run fine by hooking 12 volt power direct to the coil. It will just shorten the lifespan of the points a bit - especially with a Prestolite. The Prestolite points burn up faster than the Delco. As I said earlier - the 2010 really needs the proper coil. If it does NOT have a Deere part # on it, I suggest buying the correct coil if you plan on starting the tractor when it's colder than 20 degrees F. If you live in a warm area, then it probably doesn't matter. 2010 takes the same coil as a 6 volt 420 tractor. The original IGN switches in the 2010s did not last long and they had the "bypass" resistor built into them. Deere later came out with an upgraded switch that has the bypass-switch built into it, but a remote-mount resistor. If you have a Delco starter (not Prestolite), you don't need the special switch. Put in any old automotive-type IGN switch for battery ignition and tap your resistor-bypass from the "R" terminal on the starter-solenoid.
