Tractor Talk Discussion Forum
Sunflower Seed Plate Selection
D. Vanzant
03-27-2007 06:48:45
I am planting black oil sunflower's for doves for the first time. we are in eastern Tennesee. I am using a two row JD planter. I need help with planting advice including seed plate selection and weed maintenance. Any help would be greatly appreciated.
Cmore
03-28-2007 07:02:05
 Re: Sunflower Seed Plate Selection in reply to D. Vanzant, 03-27-2007 06:48:45
Small flat plates will work. Adjust your spacing with the chain/drive gears, want them 6 to 8 inches apart, doubles won't hurt either. Don't plant over 1 to 1/2 inches deep. Apply pre-emergence PROWL at 4 pints per acre, can also add 8 ounces of Authority...and cultivate if you want...works great for dove hunting!! Cmore
D. Vanzant
03-28-2007 07:21:23
 Re: Sunflower Seed Plate Selection in reply to Cmore, 03-28-2007 07:02:05
Thanks for the help. Sounds like you are very experienced at raising sunflowers for doves. I have received "recommendations" from the educated and the experienced educated. Other than generally stating "black oil sunflower seed", can you recommend a name/brand of sunflowers to plant? Also, I have been told that the product "Beyond" can be applied post-emerge. Do you have any experience with it?
RayP(MI)
03-27-2007 14:48:58
Have you considered using a grain drill? think that's how they do it there. Just block off unneeded ports.
ScubaInstr
03-27-2007 09:49:00
I will get the plate number tonight. I'm not too sure how it is going to translate to a JD planter tho...
I planted the Black Oil Sunflowers - Kinda like a last minute thought. Wife loved to use them in decorating around the house too.
Seems like the seeds were relly cheap too....Like $10 for 50 lbs, or something like that...
Good Luck!
Tommy D.
ScubaInstr
03-27-2007 09:20:39
I used the medium-sized corn seed plate in my Cole MX12 planter. Planted a little thick, but had a great crop. Had a great dove shoot too!
BTW, I"m down in North Ga. - Dalton area.
Good Luck!
D. Vanzant
03-27-2007 09:30:33
 Re: Sunflower Seed Plate Selection in reply to ScubaInstr, 03-27-2007 09:20:39
Thanks for your help. I am in Chattanooga. Can you define "medium-sized" corn plates? Do you have a plate number? What seed variety did you plant?
Lou
03-27-2007 07:20:59
Lincoln Ag phone 402 464 6367, you send them a sample of the seed, they make the right plates. Good luck.
D. Vanzant
03-27-2007 09:28:15
 Re: Sunflower Seed Plate Selection in reply to Lou, 03-27-2007 07:20:59
Thanks for your help!
