Tractor Talk Discussion Forum
Burn Kerosene in diesel engine?
MTrim
03-26-2007 07:58:23
I have a little over 5 gallons of kerosene left over from a garage heater. The instructions that came with the heater say not to store the kerosene over a season, then try to burn it.
Can I mix it with diesel and run it in a new JD sub-compact, or 1955 Oliver? What are my options for this fuel? Ignore the heater instructions?
JTinNJ
03-27-2007 05:57:07
 Re: Burn Kerosene in diesel engine? in reply to MTrim, 03-26-2007 07:58:23
I used to drive for a oil co. We delivered to New Jersey Transit 100% kerosene to run the buses on. They had GM diesels in the buses.I do not know what type of injection pumps the had. They had no problums at all.
I would not worry about putting 5 gal in the tractor.
richard in nz
03-27-2007 00:14:07
Often done in England, kero about 20pence/litre road diesel about 1 pound/litre, dont do rotary injector pumps a lot of good, should be ok as a mix, and you will soon use up 5 U.S. gallons anyway.
Clint Youse MO
03-26-2007 12:10:07
I leave my space heater full all summer and plug it in the next winter runs no problem that Krosene is to expensive to waste.
Clint
jdemaris
03-26-2007 11:08:36
You can run it at a 50% mix with no problems - but you don't know how much your pump-fuel already has in it.
10 years?? I've used kerosene and diesel over 10 years old with no ill effects whatsover.
$15 worth
03-26-2007 09:11:33
Just set it by the mail box and I will stop by and pour it in my truck:)
James22
03-26-2007 08:11:31
It would be easy to run thru the tractor. I wouldn't mix in more than 30% and probably stick to around 10-20%. If you run on straight kerosene, might not be enough lubrication for a rotary style pump. However it is difficult for me to believe that the kerosene would go bad over the summer. I might move it to a cooler place (basement) this summer, but otherwise I would burn it next winter.
JTinNJ
03-27-2007 05:49:52
 Re: Burn Kerosene in diesel engine? in reply to James22, 03-26-2007 08:11:31
The basement is no place for storing Kerosene.
georgeky
03-26-2007 08:05:48
I run a little of it in my tractors on occassion, We use to run it in road tractors during winter due to diesel jelling and it didn't hurt them either. I alway's mix a little motor oil with it to lube fuel pump. Last year a neighbor moved out of state and gave me two barrels of kerosene and I used it to plow ground. Burned the hole 100 gallons with no problems at all.
Ken Macfarlane
03-26-2007 12:44:07
 Re: Burn Kerosene in diesel engine? in reply to georgeky, 03-26-2007 08:05:48
Thats one heck of a nice neighbour. I got a left over stick of baseboard trim form mine lol.
Gene Davis (GA)
03-26-2007 20:07:24
 Re: Burn Kerosene in diesel engine? in reply to Ken Macfarlane, 03-26-2007 12:44:07
Well,every time a neighbor moves off around here all we get is stray dogs or cats.
