Tractor Talk Discussion Forum
Oil Weights
Steve Wiiest
03-24-2007 14:34:05
Does anyone know how much a gallon of Automatic Transmission Fluid weighs and a gallon of 80W-90??
Janicholson
03-25-2007 11:59:16
 Re: Oil Weights in reply to Steve Wiiest, 03-24-2007 14:34:05
Nice answers below, how about putting it on a good scale in a graduated container. Then the brand will not matter. You will find that they are so close it makes no difference unless you are doing some high science. JimN
720Deere
03-25-2007 06:10:04
I don't have the exact numbers, but gear oil will weigh more than ATF. I doubt the difference is any more than 0.3 lbs/gal.
Steve Wiiest
03-24-2007 18:41:38
Both brands are NAPA.
frankiee
03-24-2007 18:13:56
Could you post the exact brand of fluids?
The MSDS I have looked at so far show that they are close to the same weight or they could be the same weight.
Could you post the manufacaturer and the brand name.
Steve Wiiest
03-24-2007 17:21:16
I need to know the weight differences between the two types of oils.
Tom in Central Pa.
03-24-2007 16:46:04
Old friend used to say "A pint"s a pound the world around." I think it"s a good "rule of thumb"
Midwest redneck
03-24-2007 16:27:35
Oil weighs about 90% of water and water weighs in at 62.4 lbs. per cubic foot there is 1728 cubic inches to a cubic foot and there is 231 cubic inches to a gallon So the formula is as follows: 1728/231 X .9 = your answer.
Vern-MI
03-24-2007 15:06:41
You first need to tell us what temperature. If I remember right the specific gravity of ATF (M2C166H) at ambient (60�F) is 0.875 g/cc. The Spec. Wt. is 0.0316 lb/cubic inch. The Spec Wt. is 54.62 lb/cubic foot. The Density is (8.190E-05 lb*sec squared)/square inches squared. So a gallon of M2C166H oil at 60�F is approximately 7.2996 lbs. If I remember right I think a gallon of water is 8 lbs. Could be wrong though.
edss
03-24-2007 16:53:27
 Re: Oil Weights in reply to Vern-MI, 03-24-2007 15:06:41
TO vern I think you are correct 8.34 lbs per gal for water
Bob
03-24-2007 15:12:08
Oil on the average weighs about 7.3 lbs./gallon; water 8.33 lbs./gallon.
