Tractor Talk Discussion Forum
424 Carb Problems, Fixed it!!!!!!
ERP
03-21-2007 10:34:10
Posted last week or so about my 424 int carb problems. i done just about everything everyone said and finally fixed it.
I turned the solenoid valve (in an attempt to remove it) which backed the needle from it out of the carb ever so slightly. when i realized i could not completely remove solenoid until carb was removed again due to manifold conflict i decided to hit the start button and it fired up. if the solenoid is screwed all the way in the tractor will not hit a lick, the farther you back it out the higher it revs.
thanks for all your help.
erp
IH2444
03-21-2007 11:04:13
 Re: 424 Carb Problems, Fixed it!!!!!! in reply to ERP, 03-21-2007 10:34:10
I suspect that valve controls all the fuel flow from the carb to the engine. It would pretty much have to to kill the engine.
Thanks for the post letting us know what happened. I have not had to go into my carb yet.
Bob
03-21-2007 10:39:32
So the anti-backfire solenoid has failed and is not opening the main jet when power is applied when the switch is turned on?
ERP
03-22-2007 05:38:06
 Re: 424 Carb Problems, Fixed it!!!!!! in reply to Bob, 03-21-2007 10:39:32
they solenoid has not been connected with a wire for years and is not connected now.
