Tractor Talk Discussion Forum
new holland 1715 starter problem
wally b
03-20-2007 08:27:49
I have a 1715 new holland diesel tractor that was running fine and next day refused to start. I think the problem is in the starter solenoid because I tapped on it with a wrench and then it started right up a couple of weeks ago. However I was going to tow start it to get it out of the field to the shop. So I turned the key the oposite way to heat the glow plugs and nothing happened. So, I was wondering if the glow circuit is supposed to work if the solenoid is out.
wally b
Oldmax
03-21-2007 05:46:00
 Re: new holland 1715 starter problem in reply to wally b, 03-20-2007 08:27:49
You might save yourself some trouble if you clean battery post and ground to frame from battery also inspect battery wires , Was mowing shut tractor off couldn't get started , Same thing happend to mine cleaned those things and has started ever since . Good luck i think that will fix .
