Tractor Talk Discussion Forum
terratrac gt 34 carburetor
Charles R Wille
03-18-2007 13:51:24
I have a american tractor corp. gt-34 with a contenental engine, can anyone tell me what kind of caburetor it takes, it has a carb that is wrong, the engine runs but has no power, thanks
Charles R Willett
03-19-2007 14:47:17
 Re: terratrac gt 34 carburetor in reply to Charles R Willett, 03-18-2007 13:51:24
I found the engine #171808,chasis#34 518 carb #zenith 143742m91. thanks for all your help, this computer is hard for me
Glen in TX
03-18-2007 17:49:06
See if there is a number stamped on a tag or upper carb body itself someplace. If Marvel Schebler carb should be a TSX with 3 digits following. More specifics on year and series of F162 to still tell for sure as the F162 was used on LOTS of applications so with different linkages and all about 50 or more carbs counting Zenith also used on just a F162. MS/Zentith catalogs do list Case and Terratrac and American Tractor but not a GT34 not a F162 specific to it. Find the numbers and we can tell you if was not used on a F162 or whatever engine is in it.
J Schwiebert
03-18-2007 15:02:28
For as many different F-162 applications as there were perhaps if you can find a tag on the Carb It will round about the size of a nickel if it is a M-S built unit. Then we can cross it over and tell you what else will work. Have you checked your timing, compression,etc? Does it run better with the choke on somewhat?
george md
03-18-2007 14:39:34
Charles,
That should have an F 162 cont'l engine.
You might want to go to the case terratrac
group on yahoo , could be someone there with
a carb.
>Link
>Link george
pat sublett
03-18-2007 14:22:32
Check the engine model, if it is a Z134, It's the engine a lot of Fergusons and early Massey Fergusons had. Are you sure the main jet is not stopped up?
