Tractor Talk Discussion Forum
Hydroulic oil change
Harddriver
03-17-2007 08:01:37
I have a Massey Ferguson 35 gas tractor. I want to change the hydrolic oil an was told the filler plug is located on the transmission next to the gear shift an that both the trans and hydrolic system use from the same reservoir. Is the correct or where do you fill the hydrolic case?
Aaron Ford
03-17-2007 17:40:20
 Re: Hydroulic oil change in reply to Harddriver, 03-17-2007 08:01:37
Be sure not to overfill it!!!! I filled mine til it read right on the stick, then stopped. It took more oil than the book said. The next morning when everything had time to settle, the excessive oill was leaking out of the dipstick hole. Had to drain those two gallons back out. The fill hole is to the left of the shifters and the dipstick is on the right rear in front of the rear axle. The plugs should be 1 1/16 in wrench, and there should be two. Park it so that these are on the low side to make sure that any water drains out. Let it drain for a while cause the stuff is a little thick. Good Luck, Aaron
two mile
03-17-2007 14:20:23
Fill point is correct. If I remember it right there are two drain points, One for the transmission, and another for the differential / final drives. This is a great time to check if there is any metal flaking especially in the differential case. The Massey I had needed the main bearing replaced on the differential. This was because the pivot bushings for the 3-point rockshaft had worn through to the casting and needed replaced. There was a lot of metal floating around in there. I hope that yours is clean and golden.
135 Fan
03-17-2007 12:15:11
Yes, they use the same reservoir. Use MF perma-tran III oil for best performance. Dave
Harddriver
03-17-2007 13:41:47
 Re: Hydroulic oil change in reply to 135 Fan, 03-17-2007 12:15:11
Thanks Dave!
