Tractor Talk Discussion Forum
OT/ Painting garage doors
Rich Va
03-16-2007 05:24:25
Need some feedback from the experts here. My garage doors are metal and I'm getting some rust coming through. I know to use a preminum exterior latex but, what type of primer,kiltz or bin,water or oil base. I guess the paint thats on them is probably a baked on enamel,but I really don't know. Any advice appreciated.
Leland
03-16-2007 17:44:33
 Re: OT/ Painting garage doors in reply to Rich Va, 03-16-2007 05:24:25
Sears makes a house paint called dura bond and it is good stuff will stick to anything .even painted my alum jon boat 5 years ago and never sanded or primed it just sprayed it .
Rich Va
03-16-2007 18:19:58
 Re: OT/ Painting garage doors in reply to Leland, 03-16-2007 17:44:33
daltonwayne dealer told me autozone sells rattle can paint with the rust prevention. good to know d-w are not the only people that roll up doors are available from.
Walt Davies
03-16-2007 08:32:03
I'd check out the price of a new door I bet it won't cost much more than the paint to make it last a year or two longer. Next time get an aluminum door.
Walt
Rich Va
03-16-2007 08:49:43
 Re: OT/ Painting garage doors in reply to Walt Davies, 03-16-2007 08:32:03
A freeway is coming though my place in a few years so the paint will make it look nice when my house goes up for sale. I thought about new doors and that would be the best solution,but I won't be living here many more moons. Got to start all over,again.
Mike M
03-16-2007 07:03:54
I found out the latex paint will actually cause rust if you paint it on metal because of the water base. Use some kinda oil base paint. Paint it how you would your tractor.
Rich Va
03-16-2007 07:24:54
 Re: OT/ Painting garage doors in reply to Mike M, 03-16-2007 07:03:54
Good point. I am totally confused now.
rb/ct
03-16-2007 05:51:09
As said, use a qualtiy paint for best adhesion. Maybe latex is better than other paint because of the vibration factor. Or call the garage door manufacturer for a recommended product.
E.B. Haymakin'
03-16-2007 05:43:22
Most of your DTM-direct to metal- paints are high-high quality acrylic latexs. The newer acrylic components used have excellent adhesion. Most major paint manufacturers will have DTM's in their industrial lines- Sherwin Williams, Progress Paints also Kurfee's/Grayseal, etc. The chain store brand paints will not- Ace, Behr, Glidden. The DTM's also will have their own primers-use the entire package from one manufacturer for best results.
Kent in KC
03-16-2007 05:32:22
I'm sure some of the other fellas can add to this, but first you need to get control of the rust. Try to find what's causing it, where the moisture is getting in (hinge, bad weather gasket, etc.) and seal it. Next, wirebrush or sand the loose rust off and clean the area with solvent or thinner. I would then spray the rusted area with a product like Extend which locks the rust and converts it to essentially primer. Now, others may disagree, but I would not repaint it with latex. My preference would be an oil based or polymer paint designed for use on metal, perhaps an epoxy or urethane.
BarryfromIA
03-16-2007 17:10:15
 Re: OT/ Painting garage doors in reply to Kent in KC, 03-16-2007 05:32:22
Been there done that. Used Rust-O-lem, True Value stores have a similar product made for steel. A quart or a gallon and a hand wire brush to clean the bad spots it will look good. Any good house paint will go over it and last.
