Tractor Talk Discussion Forum
FORD 4110 SOS WONT ROLL
jcr
03-13-2007 22:54:36
NEED TO KNOW HOW TO GET TRACTOR TO FREE UP AND ROLL SO I CAN GET IT ON TRAILER BY ROLLING IT ON .IS THERE A WAY TO GET IT FREE UP LIKE IN NUETRAL .THE 3 CYLINDER DIESEL WONT RUN AND IT JUST SKIDS WHEN I PULL IT.ITS A YELLOW 1970'S IDUSTRIAL,TRACTOR.ACT LIKE IT IN PARK HAS A MULTI SPEED AUTOMATIC TRANSMISSION. THANKS FOR ANY INFO.NEED TO MOVE IT.IS THERE A WAY TOGET IT TO ROLL.
JCR
03-14-2007 14:44:51
 Re: FORD 4110 SOS WONT ROLL in reply to jcr, 03-13-2007 22:54:36
THANK YOU ALL I FREED IT UP THIS MORNING. THE LEVER WAS STUCK SO I OPENED THE INSPECTION PLATE AND AFTER SEVERAL ATTEMPTS TO FREE COLLAR A BIG OPENED END WRENCH WORKS BEST BECAUSE THE OPEN END HOOKS ON COLLAR AND PRYED IT SLIPPED IT OUT.INCH AND A HALF WRENCH I THINK MAYBE INCH AND QUARTER THANK YOU.
Kevin (FL)
03-14-2007 07:16:13
Left side on trans/differential housing--look for an offset stamped steel bracket--about 2 inches long. Remove bolt and turn bracket about 90 degrees or so. This disengages a splined collar between the differential input shaft and the trans output shaft. If it"s stuck, you can bump the tractor while trying to move the lever. If it still won"t come loose, remove the cover plate and you can use a large screwdriver to move the collar. Shift SOS lever into neutral also--(this may not be necessary but I do.)
ErnieDD
03-14-2007 04:41:56
I believe it is the same as the older sos, check the left side under the seat. There should be lever bolted down, loosen the bolt and move the lever, this will disconnect the drive line. Block the wheels, it will roll now.
Turke Bros. Farms
03-14-2007 05:08:01
 Re: FORD 4110 SOS WONT ROLL in reply to ErnieDD, 03-14-2007 04:41:56
yep search for the trans engange and disengage lever.
