Tractor Talk Discussion Forum
Huskee 50 gardent tractor - Hyrdo Trans ???
John Gildard
03-13-2007 08:42:15
I have a 2005 Huskee - Tractor Supply Company - (MTD) 50" with 25HP B&S twin V - Hyro Stat Trans with 75 hours. Runs fine on the flat but going up even samll incline I have to down shift (take foot of gas and then press gas again) to get tractor to go up the incline. Any help appreciated. Still under warranty until Sept.
Also battery is 2 yrs old and taken out in winter. Battery goes dead and I need a jump start. Hour guage blinks and won't add hours. If battery gets too low electric clutch for mower deck will not engage. Works for a while when I recharge battery.
Battery or Alternator problem?
Thanks, John G.
Rich Va
03-13-2007 11:18:13
 Re: Huskee 50 gardent tractor - Hyrdo Trans ??? in reply to John Gildard, 03-13-2007 08:42:15
I agree with Walt,take it back. And while it's there let them test the charging system. Sounds like cheap battery.
ed1
03-13-2007 11:07:10
I'll bet the belt from the engine to the trans is slipping and needs to be replaced
TomTX
03-13-2007 09:59:37
Get new battery, before you burn something out.
As to not climbing inclines; either Hydrostatic trans is going out, or motion belt is sliping. Better get it to authorized repair quick. Trans could cost you 300-600 after warranty. Tom
dhermesc
03-13-2007 11:03:06
 Re: Huskee 50 gardent tractor - Hyrdo Trans ??? in reply to TomTX, 03-13-2007 09:59:37
I agree on the battery, just removing it isn't enough. If you have it in a warm place you need to kep it fully charged.
steve_ne
03-13-2007 09:17:48
Good site for information.
Walt Davies
03-13-2007 09:13:23
If its still under Warrantee then call the company where you bought it. They should have no problem with getting back running for you.
check to see if you have on site or take in then let them fix it DON"T touch it yourself you might void the warrante.
Walt
