Tractor Talk Discussion Forum
honda 300 fourtrax
jughead 2
03-11-2007 13:27:39
Let me start by saying I know this is a tractor forum-but there is a lot of knowledge out there and I would like to pick a few brains. With that being said my 99 honda will not start I replaced the battery-I had to charge it before I placed it on the atv. I have an ampmeter that shows the battery over 12.4 when under load for starting. It is making a noise when I try to start it ( a clicking noise from near the battery) Any ideas-my next guess is the sloenoid-How does one check to see if it is operational.
Thanks
PS does anybody know of any good atv forums
BLinWMI
03-11-2007 15:50:24
 Re: honda 300 fourtrax in reply to jughead 2, 03-11-2007 13:27:39
My 2001 Rubicon did the exact same thing, I could start it by recoil but not with starter. Spent a day tearing it apart this winter, all to find out it was just a poor connection on the battery. Those do not have automotive type connectors and it seemed my posotive was making a poor connection for some reason. sanded everything down and it now starts like new.
Maark
03-11-2007 14:26:01
I would start by removing the battery cables, both the + and - and make sure the connections are clean at both ends, at the solenoid connection and the ground location as well at the battery itself.
CENTAUR
03-11-2007 14:24:26
You mean voltmeter.The battery is not under load when the solenoid is (clicking)so I would clean battery terminals first even if they look clean.Also check the other ends of the cables and loosen and move back and forth and retighten.You could well have a bad battery even if new as you have not had a load on it.You could have it load checked at most Auto Parts Stores FREE.
