Tractor Talk Discussion Forum
6 volt , 12volt voltage regulator
KCTractors
03-04-2007 19:10:25
Picked up a couple of Voltage regulators at a sale, there is no markings or numbers on them. Is there a way to determine if they are 6 or 12 volt regulators?
KEB
03-05-2007 20:49:19
 Re: 6 volt , 12volt voltage regulator in reply to KCTractors, 03-04-2007 19:10:25
There is if you have a variable voltage power supply. Connect the power supply across the field relay coil inside the regulator, and slowly increase the voltage until the field relay opens. 7 - 7.5 volts = 6 volt regulator, 14- 14.5 = 12 volt.
Keith
flying belgian
03-05-2007 05:49:28
Take them to a auto electric shop and have them set them to whatever you need.
