Tractor Talk Discussion Forum
International 460 utility won't speed up
Lyman in MN
03-04-2007 14:09:38
Can anyone tell me why this tractor will start and will not speed up? I have put heet in the gas and checked the linkage and that is working. Any ideas will be appreciated. Thanks
Please send email to my wifes addy:
[email protected]
Gene Dotson
03-05-2007 04:41:54
 Re: International 460 utility won't speed up in reply to Lyman in MN, 03-04-2007 14:09:38
Lyman;
Does the 460 use an oil bath air cleaner? My 660 and Case 700 have both collected enough water in the air cleaner oil cup to freeze and close off the supply of air to the intake... Gene
LBSMJS
03-04-2007 18:21:23
Try & remove the sediment bulb assy. from the bottom of tank.Look down in the outlet & see if it is plugged.I,ve had lots of these get plugged with all sorts of stuff.
al bane
03-04-2007 14:45:41
Sounds as though the governor is stuck or not working.The tube that runs from the carb to the governor may not be in the notch in the carb. I had a farmall 300 that did that.
