Tractor Talk Discussion Forum
Who made this hot bulb tractor?
Old_School_Nut
03-03-2007 09:42:33
well i was talking tractors with my buddies and he brought up a tractor that sparks my curiosity., this is what he had to say its long but its all he remembers about the thing. about all i gather from it is that its a hot bulb tractor, make is unkown.
�I spent some time in the mines in Africa, and there was a tractor there that I really loved, but I don't know who made it. I suspect it was Russian, because the lables had some Russian looking writing, but I could be entirely wrong. I think it said something like TS and then a number on an information plate somewhere, but I don't really remember.
It had a hood that was partially or fully orange it was also removable, and squarish in shape. It looked a bit like something that might have been designed between the 60s and 80s, but there is no telling. The combustion chamber stuck out the front. The thing was huge, and powered by one piston, which moved horizontally fore and aft, and this cylinder was massive. From the looks of it, it had to be at least the size of a volleyball or something larger.
One started the motor by first lighting a fire in front of the thing, and a steel funnel was attached to the combustion chamber over the fire. This heated the combustion chamber. After that, two people grabbed large handles on a giant wheel located on the side of the machine and attempted to turn the engine over. But once it started I don't think it was capable of even 5 mph, but it would literally move anything you connected it to. I'm telling you it was massively huge, in a very big way. :)
Aside from the hood, which may or may not have gone with the thing (I'm pretty sure it did) and the fenders (made of 1/4 or 1/2 inch steel, with ladders to climb up), it looked like a train or something. The working bits looked very old style, very similar to a LANZ but everything was tougher, bigger, badder. The body panels were squarish, with angled lines, making me think it was made later, sometime after the 60s.
It was just rediculous, like one of those massive tractors used on huge farms, only built with ancient technology. I do think it was four wheel drive, though I'm not positive. It seemed to have a massive hydraulic setup on the rear, resembling a three point, though I recall more back there, perhaps for some special application. It did have a PTO. Also As I recall, the tires were taller than me, I'm 5'8 or so so maby 6 feet, maby a little larger.�
(Again on engine startup�� he kept saying it over lol)
The engine was started by lighting a fire under the combustion chamber, which protruded in front of the front axle. The heat and flame were then directed by a metal funnel into the chamber to heat it up. I believe there was some sort of flame directing apparatus that was lost, that superheated the flame, like a volcano kettle. When it reached a certain temperature after an hour or so, two people grabbed a wheel, about four feet in diameter or larger, on the right side of the tractor (from the seated position, this wheel was on the right), by retractable handles mounted on that wheel, and turned it over, or rather, attempted to turn it over. It took some serious might to spin that thing.
Myself and a native by the name of Raphael (don't ask), the two victors in the one handed blacksmith's anvil throwing competition I started, were barely able to turn it over.
Ths wheel was connected by a belt, a huge belt, to the motor. I think this belt was the better portion of my own weight. This was no ordinary belt, it was a belt to end all belts. So far as I remember, the tractor was brought out of mothball whenever an immovable amount of rock needed to be moved, whenever an unrecoverable vehicle needed to be recovered. It's last journey was a 150 mile trak, taking months, towing a trailer full of rock that would make our biggest dump trucks blush across that harsh wasteland, as well as enough fuel to make the journey. It wasn't going anywhere in a hurry, but it definitely went wherever you pointed it.
The tractor itself was rigid, with what I would call the engine and transmission casing in one massive casting running the length of the tractor. I'm telling you, I'd have considered this thing impossible to build. If one ever had to tear it down for service, he would need the shop they use to repair those super dump trucks.
It was a cabless design, and the size of it was more impressive given the nature of the technology, and the design, rather than in comparison with modern day giants. It was like an old fashioned midsize tractor, but the size of the biguns we make today. The castings were just stupid big. The whole thing was built like a tank, from the fenders, to the frame, which was in effect a single lump of cast iron, front to back, top to bottem. Just impossibly large castings.
I mean, I've seen bigger tractors, but not built like that. It was like a diesel ship motor with wheels, and only one cylinder. I know I could have shoved a vollyball in that cylinder, maby a basketball.
There were definately backwards letters and funny letters on the information plates. At the time, I immediatly thought Russia. After all, who else but russia would build something like that, and put backwards letters on it?
-Leo-
Bernhard
03-03-2007 14:28:37
 Re: Who made this hot bulb tractor? in reply to Old_School_Nut, 03-03-2007 09:42:33
Link ?
tractorsam
03-03-2007 11:57:53
I don"t know if it"s what you"re after but a company called Ursus (Polish) made a knock off of the Lanz Bulldog. Don"t know how big they got though. Hope this helps, tractorsam
Paul from MI
03-03-2007 11:43:31
That one cylinder semi-diesel design was very popular in Europe up until the 1950"s. It will run on just about any combustible liquid that will pour. They were made by Lanz in Germany, HSCS in Hungary, Vierzon in France, & others. Modern diesels took over the market from them in the 1950"s.
Paul
Bill(Wis)
03-03-2007 10:44:18
Lenz?
dds-inc
03-03-2007 10:16:06
I wish he had a picture. Maybe it's a field marshall...only problem with that would be that there are no "russian letters" anywhere on a field marshall
Wardner
03-03-2007 11:29:29
 Re: Who made this hot bulb tractor? in reply to dds-inc, 03-03-2007 10:16:06
Field Marshalls only wiegh about 6000 lbs and they don't use a hot bulb. I think most of the bores were 6.5". Tire size varied but probably no bigger than 14-30.
Field Marshalls do not conjure up the image of "gigantic". The wheel base is very short. HP is around 40. Flywhell is about 30". Yes, I have one although it does not run.
