Tractor Talk Discussion Forum
front wheel spindles on JD 70 double front wheels
RJ
03-01-2007 21:15:55
How do they come apart from the upright that bolts to steering shaft? Bearing bosses worn out need to build up and turn down. Posted on JD board no replys, thought try here as there is lot of knowledge on this board. Any help greatly appreicated.
Thanks,
R.J.
dds-inc
03-02-2007 18:28:37
 Re: front wheel spindles on JD 70 double front whe in reply to RJ , 03-01-2007 21:15:55
If you're talking about taking the spindles out of the steering bolster, that'a a hard job. There are rivets that have to be cut off and drove out. The whole bolster needs to be heated so the spindle unit comes out. In other words, you're looking at a very hard job, especially with rust, it's almost welded up in there.
