Tractor Talk Discussion Forum
Charlynn steering
earthwrx
03-01-2007 20:12:01
I've never had the luxury of seeing a Charlynn power steering unit up close. In the case of an M, or anything similar, does the housing mount to anything or does it just float and hang by the shaft on each end? Does the torque of the unit not make it tend to rotate and pull on the hoses?
Learning to play - Playing to learn.
Steven@AZ
03-02-2007 06:50:52
 Re: Charlynn steering in reply to earthwrx, 03-01-2007 20:12:01
The arrow is pointing to the special adapter you need to mount on an H:
third party image
A couple shots of the torque motor installed:
third party image
third party image
Don L C
03-01-2007 23:53:09
On my '51 M it bolts to the light bar,two hoses lay on top of gas tank ,each going down past the guages..... looks like s**t..... .
Looks to me like it could go under the hood in front of the guages..... I will either try to move mine there or move the hoses straight dowm behind the tank.....make a metal top shield to partly hide the unit.....
gene bender
03-02-2007 06:28:12
 Re: Charlynn steering in reply to Don L C , 03-01-2007 23:53:09
I would say yours is a BEHLEN as the CHAR-LYNN goes under the hood and you dont see anything
RustyFarmall
03-02-2007 04:41:38
Don, you must have the Behlen power steering, not Charlynn. All of the Charlynn units I have ever seen install under the hood.
Allan In NE
03-01-2007 23:48:18
Here's a picture of the one I put on my H.
The torque motor on your M would look the same with the exception that it bolts directly to the special guage braket instead of using the angled donut adaptor.
Allan
third party image
RustyFarmall
03-02-2007 04:46:24
 Re: Charlynn steering in reply to Allan In NE, 03-01-2007 23:48:18
For what it is worth, that Charlynn torque motor and special bracket is now being manufactured again. The torque motor is a wee bit different, and I think it requires a little different style of hoses, but should still be a direct replacement for the original. They are being made by the Charlynn/Eaton corp.
kyred
03-01-2007 20:33:17
no you have to fasten the control and keep it stationary
BarryfromIA
03-02-2007 06:53:46
 Re: Charlynn steering in reply to kyred, 03-01-2007 20:33:17
Hi. Look up Baum Hydraulics. They list them in the catalog.
