Tractor Talk Discussion Forum
3020 JD Transmission Qustion
dirt tiller
02-23-2007 19:07:14
Does anyone have a rough estimate on what is would cost to repair the synchronizers in a 3020 transmission? It just make a vibration/grinding noise when you try to put it in 2nd/5th or high reverse. I've seen and heard this same noise on a 2510 and was told that was what was wrong with it. Thanks in advance.
johndeeregene
02-23-2007 20:36:29
 Re: 3020 JD Transmission Qustion in reply to dirt tiller, 02-23-2007 19:07:14
depends on what is all wrong with yours, i just put 3300 in the transmission, flywheel, an clutch on our 3020 diesel. new scyro's. 2 new gears. new pressure plate, an new clutch, with pressure plate.
this was all because it got to jumpin out of 1st when goin downhill, an would grind goin into 1 an 3 a little so hold on to ars, johndeeregene
