Tractor Talk Discussion Forum
3-point Quick Hitch
JonMN
02-23-2007 16:04:47
Looking for input on those quick hitchs, never had one before. Got a planter and a sprayer with a catagory 3 hitch. Other stuff is catagory 2, brush mower ect. Should I get a catagory 3 and put adaptors on the catagory 2 stuff? Also are there good better best quick hitchs? Thanks for your input Jon
MF294-4
02-23-2007 18:32:34
 Re: 3-point Quick Hitch in reply to JonMN, 02-23-2007 16:04:47
I've got a quick hitch from Tractor Supply, and it works OK. I would like to try some of those links that you can extend. I think they would be very good. Grew up on IH fasthitch, can't understand why others didn't adopt this. Three point is a pain compared to fasthitch.
Armand Tatro
02-23-2007 16:30:56
Once you have used a 3PT quick hitch you will how you ever got along without one. I, H. & J. D. both make a cat. 2/3 quick hitch. Main thing when hooking up is be pins are seated and latches
are latched. I would not want a 3PT, loader, or combine header without quickhitches! Armand
paul
02-23-2007 16:22:22
For me the catagory 2 & cat 3 hitches measure out the same.... It is a cat 3N for 'narrow'. The only difference is the pin sizes. Be sure you aren't running a regular cat 3, which is wider.
That makes it easy. Just use the right bushing or right pins.
I run a cat 3N quick hitch, as I use the same tractor to field cultivate & the 3pt bean planter. Lot of switching in wet springs.
The stumbling point with quick hitches is some implements don't have the clearence for the top hook to slip up into the top pin area. Be sure your implements don't have a stupid beam or bolt in the way.
--->Paul
