Tractor Talk Discussion Forum
magnedo
goodjunk123
02-22-2007 20:55:24
I just got done putting a new mag on my 47 case vac and it fires, but I can"t get it to run. can you tell me what I did wrong? it only goes on two ways. it back fires and hits a couple times and thats it. please help, thanks Dale
Glen in TX
02-23-2007 14:09:07
 Re: Magneto ! in reply to goodjunk123, 02-22-2007 20:55:24
Case mag? Make sure the dot on steel gear by cam for points aligns with the beveled teeth on dist. rotor gear or it won't time right. Beveled teeth on fibre gear must be towards the rotor disc or gear is on backwards and will throw it off also. Other mag? Post back with brand and model#. Recheck timing again.
Coloken
02-23-2007 06:27:19
 Re: magnedo in reply to goodjunk123, 02-22-2007 20:55:24
Not 2 ways--4 ways, There is a two to one gear driving the distributor. Could be a full turn off.
RAB
02-22-2007 22:48:18
What Old is saying is:
1) Check firing order, 2) check rotation direction of mag distrbutor, 3) find #1 cylinder top dead centre on compression stroke and 4) connect plug leads in their correct order. Then it will likely run.
Regards, RAB
old
02-22-2007 21:08:58
Switch the wires 180 out and it wil most likely run.
